20 Most Recent
AEG L62600 Front Load Washer Questions & Answers
Aeg L62800. No lights / signs of power
hello yes there should be 1 on the power board inside the washer glass type beware if you put another 1 in and it blows again then theres a dead short on the board. also make sure you put the same rated fuse back in if you do not find a glass fuse there might be a soldered in fuse called a wickman i hope this help
regards
shaun
E93
E93 is showing that the configuration code has not been put into the new Module if no configuration code came with the module then you will need to send me the p.n.c. of that model and I will get the correct code.
Hope this helps.
Good Luck
Wont drain
The Hmming could say the pump works just fine. But I'm sure the not draining is caused a Valve in the Pump being dis-aligned or something. Try to contact service repair guys, or call and describe the fault :)
Washing machine aeg 64840
Remove the line to the water level sensor, release the vacuum and it might solve. Also check inlet and drain blocks.
If the
water flows though the inlet then the flow pressure should be good, if not the
inlet valve is bad or there is dirt in the filter. Also check the flow at the
inlet of the water line. Once the water comes into the system the WATER LEVEL
SENSOR - normally a pressure switch- must activate at the preset/chosen level
to give the signal to the program controller to switch on the motor. What is
most important for the motor to start functioning is that the door switch must
be ON when the door is shut or this will be an error for starting the motor for
rinse and wash.
