20 Most Recent
AEG Lavamat Lavalogic 1600 Front Load Washer Questions & Answers
Lavalogic 1620 fails to come on - there is power
I also have problems with AEG Lavalogic 1600. It is caused by the control knob and the poor contacts. One service repair person fixed it and lasted 1 month. Then the problem reappeared. Now, I turn on the knob and the machine does not turn on, but I push lightly the button, not to a full path, just to cause a contact and it starts.
Lavalogic 1620 leak from rectangular hole at top of unit
is your inlet water pipe pointing straight down?i have read the instruction manual for this machine and it says to have the inlet water pipe turned 90 degrees to the left or right. is the rubber seal firmly in place? hope this helps..
C5 is showing
C5 generally indicates a motor fault, specifically overheating. things that might make motors overheat are worn bearings and restricted ventilation
I have a recurrent C9 error code on my AEG 88840
The fault code indicates a motor fault.
Unplug the appliance from the wall socket before beginning.
Check the carbon brushes in the motor, this is the most common cause of the fault.
There is one carbon brush either side of the rear of the motor.
You
will have to take the motor out to check them, unless you are very
nimble and can do it from underneath while the machine is tipped back 45
degrees.
You'll probably find the carbon brushes are worn out.
If you can identify them from the pictures on Ebay, you'll be able to order them and save money on them too.
http://shop.ebay.co.uk/items/?_nkw=aeg+carbon+brush&_sacat=0&_fromfsb=&_trksid=m270.l1313&_odkw=lav72620&_osacat=0
If you email the seller they should be able to tell you which ones fit your model.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
