20 Most Recent
Avanti W789SA Top Load Washer Questions & Answers
Drain hose cracked and leaks water
You just have to replace it. Try these sites for spares with your model number, etc:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Washer don't drain the water
Hi
Thanks
for using FixYa. Usually water not draining at all is due to the drain
line that is clogged and/or because of kinked drain hoses that’s attached to
the Drain Pump. In many washers, a small sock or other
piece of clothing can get between the clothes tub and the outer tub that holds
the water. If the clothing gets between the tubs, it may then get into the
drain hose that's attached to the pump--or even into the pump itself. If it's
in the pump, you need to remove the hoses from the pump and pull the item out. To
remove the sock from the outer tub port, open the washer's main access panel
and remove the large-diameter rubber hose that connects the pump to the bottom
of the outer tub. Then, using needle-nose pliers try to grab and remove the
clothing through the port. Sometimes you can't remove the stuck clothing from
below. Then you have to remove the agitator, top of the outer drum shield, and
inner clothes tub. If you think that this isn't easy to do--and you may need
special tools—then you might be happier getting a qualified appliance repair
technician to do the job. If the drain line isn't plugged, the problem may be
with your pump. Even if the pump appears to be turning, the internal impeller
may be broken. If so, you need to replace the pump. Please do accept the
solution if the issue is resolved or post a comment for further
assistance.
Thanks
Rylee
Wont spin or turn
It may be a bad belt. Check the spin bearing and the basket drive also. Both of these control the spinning of the machine. If you have a question, let me know. I am here to help you the best I can.
Smell of stale water from Avanti compact washer
It may not be draining very well. I have a front load washer and run a cycle of a few cups of bleach through mine every couple months.I also add vinegar to most washes but that's due to my teenage son's athletic wear.Both those things do the trick.You shoudl probably check the mechanics as well but the above is a stop gap.
