20 Most Recent Equator EZ 3600 CEE Front Load Washer / Dryer Questions & Answers
When I plug in my Equator EZ4000, all lights on the display panel illuminate and stay illuminated. They don't change to reflect the functions being performed.
If all lights on the display panel of your Equator EZ4000 washer dryer illuminate and remain illuminated without changing to reflect the functions being performed, it could indicate a malfunction with the control board or a possible software issue. Here are a few steps you can try to troubleshoot the problem: 1. Power cycle the unit: Unplug the Equator EZ4000 from the power source and wait for a few minutes. Then, plug it back in and see if the display panel resets and functions properly. Sometimes, a power cycle can help reset the control board and resolve minor software glitches. 2. Perform a factory reset: Refer to the user manual or contact Equator Appliances to find out how to perform a factory reset on your specific model. This process typically involves pressing certain buttons or a combination of buttons on the control panel to initiate the reset. A factory reset can often resolve software issues and restore the display panel's functionality. 3. Contact customer support: If power cycling and performing a factory reset do not resolve the issue, it is recommended to reach out to Equator Appliances' customer support directly. They can provide you with specific troubleshooting steps based on your model and guide you through the process of resolving the display panel problem. They may also be able to assist you in scheduling a service visit if necessary. It's worth noting that working with electrical components can be hazardous, so if you're uncomfortable or unsure about performing any troubleshooting steps yourself, it's best to seek professional assistance from Equator Appliances or a qualified technician.
5/25/2023 5:35:18 AM • Equator EZ 3600... • Answered on May 25, 2023
2answers
My equator clothes processor ez2500 is leaking water from the bottom..where can i get parts to fix it?
Please contact Appliance Desk or Equator to get Tech Support & Parts for your machine. their contact no is 713 464 3422 or 713 464 3858 Ext 186 / 175
10/9/2022 1:10:59 PM • Equator EZ 3600... • Answered on Oct 09, 2022
Where can i find parts for equator washer dryer combos
Call 888-483-9627 they should be able to help you.
4/13/2021 4:53:25 PM • Equator EZ 3600... • Answered on Apr 13, 2021
My clothes don't dry. There is heat but the clothes are wet.
most likely a clogged up vent
11/17/2019 12:30:43 AM • Equator EZ 3600... • Answered on Nov 17, 2019
0answers
Water not draining even after reset attempts
Did you check the most obvious item - the motor and belt that spin the drum and powers the pump assembly
9/12/2017 9:21:05 PM • Equator EZ 3600... • Answered on Sep 12, 2017
0answers
I have a 12 year old equator clothes processor
yes try ebay?
2/2/2016 8:15:20 PM • Equator EZ 3600... • Answered on Feb 02, 2016
How do I replace pump on washing machine
http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ you should check other things b4 replacing pump as it may be other issue? Washer will not drain: Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement. Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed. If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
2/2/2016 8:04:13 PM • Equator EZ 3600... • Answered on Feb 02, 2016
How do i clean the impeller?
ELECTRIC Dryer no heat or little heat, or shuts down to fast: Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it) Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating. The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance. Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220, OR you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run , the heater should not heat in order not to create fire but if the motor is not running, and the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater. Check the thermal cut off, the cycling and the hi limit thermostats. For continuity or OHMS. If no ohms or resistance they need replacement. In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?) Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet. Test with a meter at room temperature and it should show continuity. A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats. Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE How to Check Dryer Thermistor eHow 25673986-wkaz2joxiaagz3w0xil1scpn-1-0.jpg 25673986-wkaz2joxiaagz3w0xil1scpn-1-2.jpg 25673986-wkaz2joxiaagz3w0xil1scpn-1-5.jpg
2/2/2016 7:58:36 PM • Equator EZ 3600... • Answered on Feb 02, 2016
It will not spin drain the water, lint trap is clean, drain hose is hooked up tight to machine, go to spin but will not spin,
No water? Or wash agitation or spin? try these: WATER PRESSURE SWITCH: This switch keeps your washer from overflowing. It is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has been reached. Meter check ur water pressure switch? You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good ( No wash starts - then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ? Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open. Another test u can make with a multi meter is by testing the prongs individually. # 15,16,17 (don't worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch. (where the wire plugs into) take note of weather it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open. . Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly. Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it. Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed. Transmission or clutch assembly not engaging due to going out or slipping. Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design. Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly. CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub) Remember to check the agitator spline as well for worn broken teeth. By the way my advice is free cuz God is good! 26078014-wkaz2joxiaagz3w0xil1scpn-1-0.jpg 26078014-wkaz2joxiaagz3w0xil1scpn-1-2.jpg 26078014-wkaz2joxiaagz3w0xil1scpn-1-5.jpg 26078014-wkaz2joxiaagz3w0xil1scpn-1-9.jpg 26078014-wkaz2joxiaagz3w0xil1scpn-1-14.jpg
2/2/2016 7:45:48 PM • Equator EZ 3600... • Answered on Feb 02, 2016
0answers
Won't dry
Be the first to answer 2/16/2014 4:14:36 AM • Equator EZ 3600... • Posted on Feb 16, 2014Be the first to answer
0answers
No heat
Be the first to answer 1/27/2014 3:47:48 AM • Equator EZ 3600... • Posted on Jan 27, 2014Be the first to answer
0answers
Leaking
Be the first to answer 1/17/2014 3:31:48 AM • Equator EZ 3600... • Posted on Jan 17, 2014Be the first to answer
My clothes processor is >12 years old and the
buy a new one :} maybe? hope I helped :}
9/13/2013 5:37:06 PM • Equator EZ 3600... • Answered on Sep 13, 2013
Equator EZ 3600 CEE Front Load Washer / Dryer Logo
82 questions posted
Top Equator Washing Machines Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Equator Washing Machines
Most Popular Question
own equator clothes
  • Washing Machines
