20 Most Recent Hotpoint WMA50 Front Load Washer Questions & Answers
Can someone please share Hotpoint WMA50 schematic diagram?
Hi thanks for question. https://www.manualslib.com/manual/71009/Hotpoint-Aquarius-Wma50.html?page=10#manual
10/12/2022 5:21:40 PM • Hotpoint WMA50... • Answered on Oct 12, 2022
My hotpoint wma 50 will not spin leaving all the clothes wet and water started to come out wash programme seemed very slow
The plastic ball is fine. Either it's filter that need remove to clean and replace or the pump.
12/15/2017 10:55:08 AM • Hotpoint WMA50... • Answered on Dec 15, 2017
Hotpoint WMA50 won't final spin, and water stays in drum
Running with a restricted water supply probably took out the pump.
The stator requires a steady water supply for cooling and lubrication. Without this accelerated wear between the stator & magnetic poles occurs.
This additional clearance makes the magnetism insufficient to spun the impellor.
10/17/2017 1:20:23 PM • Hotpoint WMA50... • Answered on Oct 17, 2017
Door locked indicator light flashing
reposition the switch.. in the door
first try holding button at door with finger and press start..if same symptom appears...check tab that depresses that switch and if its good try to reposition or replace switch.
4/4/2016 9:16:14 AM • Hotpoint WMA50... • Answered on Apr 04, 2016
Door will not lock Led flashing
Door switch fault.
1/7/2016 12:49:24 PM • Hotpoint WMA50... • Answered on Jan 07, 2016
How to replace carbon brushes
There are no Carbon brushes in this washer.
3/15/2015 9:31:49 AM • Hotpoint WMA50... • Answered on Mar 15, 2015
My WMA 50 hotpoint is leaking fronm around clip beside filter. It is the small pipe that heads towards the drawer
It might be something lodged in the pump, have you tried to remove the pump and clean it?
10/11/2014 11:08:51 AM • Hotpoint WMA50... • Answered on Oct 11, 2014
When the 'wash' cycle finishes, the machine stops at the 'rinse and spin' cycle, and the 'prewash' LED flashes.
Victor. The prewash flashing is indicating a water fill issue. Rinse uses cold water only. check for clogged inlet screen on the cold water valve, and check if there is a screen on the supply valve also. If the inlet screen is all clogged up at the valve on the washer, you can clean it with a little windex and an old soft tooth brush. gently brush away any sediment or debris. If no filters are clogged, you will need to replace the fill valve assembley.
4/11/2014 2:37:55 AM • Hotpoint WMA50... • Answered on Apr 11, 2014
0answers
Ultra sense dryer won't start
-Possibly bad door switch, burn heater element, bad thermal fuse, bad starter switch Mai
12/21/2013 3:04:12 AM • Hotpoint WMA50... • Answered on Dec 21, 2013
0answers
If i leave the washer taps,red/blue ones in the on
Bad water inlet valve possibly. Or could be water level pressure switch; air dome tube.
9/24/2013 7:34:07 AM • Hotpoint WMA50... • Answered on Sep 24, 2013
2answers
Fabric conditioner drawer retains water after
This video will show you how to keep your soap draw clear and how to service the parts Please remember to subscribe to our YouTube channel for all appliance tutorials a 4 THUMBS rating is appreciated for answering your FREE question.
8/2/2013 9:42:31 AM • Hotpoint WMA50... • Answered on Aug 02, 2013
Hotpoint WMA50 Front Load Washer Logo
104 questions posted
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
when wash cycle finishes machine stops
  • Washing Machines
