20 Most Recent
Summit SPWD1470C 24 Inch Washer Dryer Combo with 13.5 lbs. Wash Capa Questions & Answers
Summit washer/dryer combo quit drying. Repairman
summit washers are prone to board failures i would say that is where the fault lies . thermafuse fuse means it has been overheating. means it can damage other parts. thermostat would thing that has just worn out thermostat can go if the unit overheats. under line is an electrical fault. but like i've said it is a common fault with this make and others. the main boards can only handle around 50c in temp after that they start to over heat and cause problems. the faults started when they moved the main board from the bottom to the middle.
My top loader Hisense washing machine doesn't wash but it spins, what is the possible solution?
If your Hisense top-loading washing machine is not washing but can spin out the water, it could be caused by a few different issues. Here are a few things you can try to fix the problem:
- Check to ensure that the washing machine is properly loaded and balanced. An unbalanced load can cause the machine to stop working or not wash properly.
- Check the water supply to the machine. Make sure that the water hoses are properly connected and that the water supply is turned on.
- Check the detergent dispenser to make sure that it is not clogged. A clogged dispenser can prevent the detergent from being dispensed and the machine from washing properly.
- Check the lid switch. If the lid switch is faulty, the machine may not wash but will spin out the water.
- Check the water level switch. If the water level switch is faulty, the machine may not wash properly but will spin out the water.
- If the problem persists, consider contacting Hisense customer service or a technician for further assistance.
It's essential to note that if the machine is not washing but it can spin out the water, it could be caused by a malfunction or damage in the water level switch, the timer or even the motor.
Gorenje washing, why does it stop with 1 left ?
Your NOT suppose to "Program anything". Machines are kinda like people. After they work, they need "some" time to rest. Your machine (And Mine) all do this. Next time leave it alone, the minute will count down and it will automatically shut off. Question? You actually stood by the machine and watched the entire cycle? Was there another problem that motivated you to do this? Like your clothes were still wet or water still in the tub? If you need further help, reach me via phone at
https://www.6ya.com/expert/steven_b77d19396bfe2249
I want to bypass lid lock
It would be innapropriate to recomend the removal of a safety device.
I would repair it, not remove it.
