20 Most Recent
Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2) Questions & Answers
Right analog stick not working
Check the controls on the game's control section. If you play another game that uses the right analog control and it works on that game then it's the control set up for FIFA. Make sure that the analog control light is on when the game boots up. Sometimes if the analog control light is not on when you turn the game on and you turn it on afterwards, the analog stick controls don't work properly. That happened to me on NFS Pro Street. If this helped you leave feedback please. FIXYA!
PS2 Controller. D-pad does not
I know the answer.
I had the exact same problem, D-pad keys no working along with L1 & L2.
Reason of problem: there is a circuit made of carbon on a plastic sheet under the keys (once you open the controller that is..) that circuit is severed somewhere near the D-pad keys because it gets worn off by pressing the keys.
Solution: I had some "wire glue" and reconnected the circuit with it and now all keys are working!
Here is a picture for you to see what I mean:
http://i.imgur.com/bL7THqU.jpg
It's difficult one but doable..
Something so little spoils the whole controller!!
Ps2 controller buttons not working
what you can do is open
the controller clean the board by using cotton buds with alcohol or
cleaner you will notice accumulated dust preventing the buttons from
touching the board you need to remove those.
My sony ps2 have black and white output to tv
hey it is due to the model of your ps2 and your game is PAL and your TV is NTSC or the other way then it would give you black and white screen.the model of ps2 is written on its back side if both your tv set and game and ps2 are pal then there might be a problem with your ps2 av cable or ps2 itself
Character moves side ways without me touching it.
go to control panel and open "game pads" or "game controllers"
then choose properties for your game pad and choose the calibration tab, calibrate and set click ok and check if problem has been resolved
