20 Most Recent Sony VAIO PCV-RX462DS PC Desktop Questions & Answers
My CD-ROM doesn't work
ok what you can try is go to your device manager (type devmgmt.msc in run) uninstall and reinstall cd rom drive under opitcal devices
6/1/2011 6:51:11 AM • Sony VAIO... • Answered on Jun 01, 2011
How do i use a wireless modem on my sony vaio
type in IE 192.168.1.1 then fallow the instrection
6/24/2010 4:51:54 AM • Sony VAIO... • Answered on Jun 24, 2010
SONY PCV-rx462ds won't power up after 3 y of inactivity
please to reset all cables inside your computer. the power supply, memory modules (have it clean), the processor, the IDE or SATA cables, the video card then try it. see if it works.
5/13/2010 1:50:23 AM • Sony VAIO... • Answered on May 13, 2010
2answers
CD drive not working
Based on your indication the CD drive is clean, and you know the cables are attached to it, inside the computer. (Flat ribbon IDE interface cable, and 4-pin Molex connector power cable)
1.Go to Device Manager
Left-click on Start. Right-click on My Computer. Go down, and Left-click on Properties. Left-click on the Hardware tab. Go down, and Left-click on Device Manager.
Left-click on the + sign to the left of, DVD/CD-ROM drives.
Right-click right on the name of the CD drive.
(Example: Lite On DVDRW LH-20A1P.
eMachines Support indicates the T5212 has a DVD burner drive, and a CD drive. Right-click on the CD drive name))
In the drop down list, Left-click on Properties.
Left-click on the Driver tab
Go below, and Left-click on the Update Driver 'button'. Now go below, and Left-click on OK.
Close all windows, go back to your desktop screen.
Shut your computer down normally. (Start>Turn Off Computer>Shut Down)
Do Not Restart. We need a 'Hard Shut Down'.
Wait 1 minute, turn your computer on.
Still doesn't work?
Let's play hard ball.
2.Go back to Device Manager. Left-click on the + sign to the left of DVD/CD-ROM drives. Right-click on the name of the CD drive. Left-click on Properties. Left-click on the Driver tab.
This time go down, and Left-click on the Uninstall 'button'. Go below, and Left-click on OK
There will be a Microsoft 'squawk box' that comes up. "Warning you are about to uninstall this device"
Left-click on OK. (It IS okay!)
Close all windows. Shut down your computer normally. (Again, we need a 'Hard Shut Down'. To Restart a computer is known as a 'Soft Shut Down')
Wait 1 minute. Turn your computer on.
After Windows loads all the way, and all of your Start Menu programs have loaded, you should see a pop-up out of your system tray. (Bottom of Windows desktop screen)
"Found New Hardware", and perhaps another one, "Found XYZ CD drive". (XYZ = the CD drive name)
No still?
The driver for your CD drive, is located within the Windows XP operating system on your computer.
If your CD drive does not work now, I suggest it has failed.
Drives such as Optical drives, and Harddrives, are mechanical devices. Their 'Lifespan', is rated in so many hours of usage. Your CD drive may be at the end of it's 'Lifespan'.
10/4/2009 4:40:57 AM • Sony VAIO... • Answered on Oct 04, 2009
My cd-rom wont work
The laser lens needs cleaning.
Radio Shack has a CD laser lens cleaner ($13).
It is an audio CD with a row of brushes on it.
Read and follow directions. It does not use chemicals and will not harm your CD drive if not done correctly.
9/30/2009 8:15:34 PM • Sony VAIO... • Answered on Sep 30, 2009
Cd rom doesnt work at all
hi if ur system is provided with two drives then u can use the second drive.. if not then u have to go for a change of new rom..since u said that ur light wont even flash it means that ir drive doesnt detect that particular rom and it has got damaged....
thank u rate me
2/9/2009 3:04:58 AM • Sony VAIO... • Answered on Feb 09, 2009
I have a sony vaio,
Hi try taking the drive out of the laptop,you may have to unscrew some screws under the drive first .Make sure you have the laptop turned off when doing this.When you have the drive out put it back in firmly then put the screws back in.This may sound stupid but sometimes this is all it takes.
12/24/2008 11:16:59 PM • Sony VAIO... • Answered on Dec 24, 2008
0answers
Cd drive problem
Be the first to answer 10/20/2008 2:35:02 PM • Sony VAIO... • Posted on Oct 20, 2008Be the first to answer
CD DRIVE
  • go to start
  • right click on "my computer
  • down to ,and click on properties
  • go to hardware tab
  • click on device manager button
  • click on the + sign next to dvd\cd drives
  • if a drive is present,right click on it and un-install it, if one is not present,
  • go to "actions" menu on top of the device manager box,and select "scan for hardware changes".
  • reboot and windows should find it when it boot's up.
  • if not you need a new drive
good luck
Terry
3/30/2008 1:06:01 PM • Sony VAIO... • Answered on Mar 30, 2008
My computer wont read discs anymore
just clean it the disk cleaner, if not work
remove the cd/dvd drive into your pc then i have knowlegde how to repair it just open the casing and replace the belt in the gear then wipe the lens with clean cotton.
if not work i suggest you to buy a new cd/dvd drive because the lens of that cannot read.
3/5/2008 2:13:01 PM • Sony VAIO... • Answered on Mar 05, 2008
Cd drive
Try having your cd drive cleaned. A cd drive could prevent the cd drive to read the disk properly. The drive noise is normal if the speed of your cd drive is high. Here are some links on how to clean a cd drive:
http://www.deinmeister.de/cdrep_e.htm
http://www.ehow.com/how_2044857_clean-cdrom-drive.html
Here is the link for reducing the speed of the disk (if the sound annoys you):
http://hektor.umcs.lublin.pl/~mikosmul/computing/tips/cd-rom-speed.html
11/22/2007 10:45:44 AM • Sony VAIO... • Answered on Nov 22, 2007
3answers
Typing in a electronic medical record online. the
If you only erased it, you can simply use the keyboard shortcut CTRL+Z, if the deletion was permanent, there is nothing you can do.
12/22/2022 9:08:06 AM • Sony VAIO... • Answered on Dec 22, 2022
5answers
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop. Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185) This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information. Causes of Error Code 0xc0000185:- 1. Suffer a cable attachment joining to your system and the hard drive. 2. Defective or missing boot files. 3. The disk drive gets damaged. 4. Wrong disk drive. Solutions of Error Code 0xc0000185:- 1: Do sure that Wire is Correctly Connected [Only for PC] 2: Automated Repair 3: Check Hard Disk for Errors 4: Repair your System to Fix Error 0xc0000185 Full Solution - Error Code 0xc0000185 wgnanor-undefined-undefined-0_3.jpg
9/14/2022 11:53:07 AM • Sony VAIO... • Answered on Sep 14, 2022
Nao consigo instalar o drive de controle de massa no meu Sony Vaio PCG-792L. Como devo fazer
www.driverguide.com use the 2 drivers free install per day freature. it will help you for sure
1/23/2019 7:29:29 PM • Sony VAIO... • Answered on Jan 23, 2019
How can dennythedon3003 help - if only he spoke English
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
11/30/2018 6:39:57 PM • Sony VAIO... • Answered on Nov 30, 2018
hi, you mean it doesn't give you any option to adjust? (adjustments options are disabled?). have locate under power option menu? thanks
11/30/2018 6:38:47 PM • Sony VAIO... • Answered on Nov 30, 2018
Denythedon3003 fixya spam loser - guess what country he's from - maybe Tom can block him
This can be a faulty inverter or a faulty CCFL lamp. Pleaseclick on this link and follow my instructions to identify the fault andpossible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
11/30/2018 6:25:34 PM • Sony VAIO... • Answered on Nov 30, 2018
Sony VAIO PCV-RX462DS PC Desktop Logo
17 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
cd drive not working
  • Computers & Internet
