20 Most Recent Zanussi FLA1101W Front Load Washer Questions & Answers
My zanussi washing m/c is leaking from the front of the drum
Could be door boot seal or indeed the drum having a hole in it, the seal is simple to do drum is not worth while.....Although a good grade Silicone would seal it...
1/8/2018 4:10:12 PM • Zanussi FLA1101W... • Answered on Jan 08, 2018
Last load of washing has lots of black dirty marks on them
It would appear that the drum seal and bearings have failed. If you have been doing constant cold water washing and using fabric softener and the machine is over 5 years old, I would say its time for a new machine. There are not many that last past 5 years any more especially with cold water and fabric softener usage. Bearing and seal replacement can be very expensive. The drum shaft (Spider assembly) will probably need changing as well.
12/21/2017 12:36:40 AM • Zanussi FLA1101W... • Answered on Dec 21, 2017
2answers
How do you change the
With the help of someone, tilt the washer forwards towards you, this will give you more room to get your hands inside to fit the belt, it is awkard, but can be done, I have done it this thay on many occasions, otherwise, it entails removing the rear half of the cabinet, not an easy job!!!!!¬.
Good luck.
3/18/2011 12:41:22 AM • Zanussi FLA1101W... • Answered on Mar 18, 2011
Zanussi Model FLA 1002W Washing m/c.
my w.m. is very noisy, after cycle laundry is with black spots on and white bits on clothing but it is not tissues. ?
8/14/2010 12:30:24 PM • Zanussi FLA1101W... • Answered on Aug 14, 2010
Location of bearings on a zanussi fla100w
how do you change bearings on zanussi fla 1101W
7/24/2010 12:24:47 PM • Zanussi FLA1101W... • Answered on Jul 24, 2010
Sticking mid cycle.
suspect heater circuit or pressure swirch
6/28/2010 12:07:35 PM • Zanussi FLA1101W... • Answered on Jun 28, 2010
Does not empty the water and does not rinse or spin
Need to remove pump to open and check what is sticking in the impellar. Check pipes for blockages. Also check pump motor by itself. reassemble and retry.
6/6/2010 2:31:07 PM • Zanussi FLA1101W... • Answered on Jun 06, 2010
The dial for the different types of washes is just spinning
If I am correct in my assumption that when you set it to a certain programme it seems not to be at the correct one that you thought.Then this is not the timer at fault but some little plastic cogs behind the control knob when these break either due to normal wear and tear or some one trying to turn the timer the wrong way.The Main cam and the indicator will need replacing.This is not an exspensive repair for parts anyway.
Hope I was of some help.
Good Luck
5/5/2010 10:35:13 PM • Zanussi FLA1101W... • Answered on May 05, 2010
From what you describe, I would agree with you in concluding that the main drum bearings have gone.
Problem is, until it is stripped down, there is no way of knowing if it has worn the drum shaft.
This being the case, then it it is really beyoind economical repair.
3/29/2010 12:13:50 PM • Zanussi FLA1101W... • Answered on Mar 29, 2010
Broken bearing
not sure whay you wish to know, replacing the bearings is quite a big job/ expessive if over 5 yrs old suggest new machine....
2/23/2010 1:13:23 PM • Zanussi FLA1101W... • Answered on Feb 23, 2010
The letters on the program selector have worn off
replace with new one and put clear nail varnish over print :) so wont happen again01179512835
12/30/2009 12:45:54 PM • Zanussi FLA1101W... • Answered on Dec 30, 2009
Does not spin
Hi friend
did you see anything stuck under tub ,,,,,,if not then its a timer problem,check it...
thank u,,
5/3/2009 11:54:37 AM • Zanussi FLA1101W... • Answered on May 03, 2009
Need dimension of Zanussi Aqua cycle 400
1/4/2024 9:07:00 PM • Zanussi Washing... • Answered on Jan 04, 2024
Zanussi Washer dryer ignoring all programs and just does a pulsing humming sound (Only works well on reset mode)
It seems like you've done a thorough job troubleshooting so far. The E69 error could be related to a heating issue. Since you've already replaced the heating element, it's worth checking the thermal fuse. The thermal fuse is a safety device that can sometimes cause E69 errors if it's faulty. Given that you have access to a spare machine, you might consider swapping the thermal fuse from the spare machine to see if it resolves the E69 error on your primary machine. If the spare machine's thermal fuse is in good condition, it could be a step toward identifying and solving the issue without having to switch the drums. Remember to disconnect the power source before attempting any replacements, and I hope this helps you get your tumble dryer back in working order.
12/5/2023 9:07:17 PM • Zanussi Washing... • Answered on Dec 05, 2023
Zanussi ZWF1640 - at start of wash, all the lights go off and it jumps to end of cycle
May try resetting the breaker turning off turn on
9/1/2023 7:50:24 PM • Zanussi Washing... • Answered on Sep 01, 2023
Zanussi ZWF1021W Washing Machine bearing replacement?
Take a look at the videos. You will need a bearing and seal kit, plus some grease. You can knock the old bearing out using a large socket on an extension bar. That is also useful for gently seating the seal without damaging it. https://www.google.com/search?q=Zanussi+ZWF1021W+Washing+Machine+bearing+replacement Later machines have the bearings bonded to the drum. Truly a bad idea! https://www.ukwhitegoods.co.uk/forums/forum/public-support-forums/help-and-support/washing-machine-help-forum/31703-zanussi-zwf1431w-bearing-replacement ..
7/28/2023 4:03:25 PM • Zanussi Washing... • Answered on Jul 28, 2023
Zanussi washing machine door seal metal wire ring has come off, how do I put it back?
To put back the metal wire ring on the door seal of your Zanussi washing machine, you can follow these steps: Ensure safety: Before starting any repair work, make sure the washing machine is unplugged from the power source to avoid any accidents. Locate the groove: Examine the door seal and locate the groove where the metal wire ring needs to be inserted. The wire ring typically fits into a groove on the inner edge of the seal. Position the wire ring: Take the wire ring and position it in your hands so that it forms a complete circle. Make sure the ends of the wire are close together. Start at the top: Begin by inserting one end of the wire ring into the groove at the top of the door seal. Apply gentle pressure and work your way around, pushing the wire into the groove. Use your fingers or pliers: Depending on the size and tightness of the wire ring, you may be able to push it into the groove using your fingers. If it's difficult to do so, you can carefully use a pair of pliers to assist you. Be cautious not to damage the wire or the door seal during this process. Continue around the seal: Slowly and steadily work your way around the door seal, pushing the wire ring into the groove. Take your time to ensure that the wire is securely in place and properly seated within the groove. Double-check the installation: Once you've inserted the entire wire ring into the groove, double-check that it is evenly positioned and properly seated. Ensure that it's securely holding the door seal in place. I'm Sophia and CEO of Homyclean, and I love sharing my amazing cleaning, laundry, bathroom, best washing machine cleaners and maintenance experiences with you. I'll share hassle-free methods and top-notch products for washing and cleaning, fueling your passion for cleanliness. By following these steps, you should be able to successfully put the metal wire ring back on the door seal of your Zanussi washing machine. If you encounter any difficulties or the wire ring doesn't fit properly, it's advisable to consult the manufacturer's manual or seek assistance from a professional technician.
7/2/2023 5:45:55 AM • Zanussi Washing... • Answered on Jul 02, 2023
Zanussi FLA1101W Front Load Washer Logo
Popular Tags
28 questions posted
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Washing Machines
Most Popular Question
change
  • Washing Machines
