20 Most Recent
Kipor RV Generator Sinemaster IG3000 Questions & Answers
The generator shuts off after 30 minutes with an oil level alert but oil level if full
Your oil level sensor is bad. It needs to be replaced. If you unplug the wire leads to the sensor you may get the generator to run, but you'll have no low oil level/pressure protection. The oil level sensor is on the engine crankcase usually near the oil level dipstick. You'll likely see a small sensor with a couple of wires attached to it. To replace it, you'll need to drain your engine crankcase before removing the sensor.
10/25/2021 5:26:03 PM •
Kipor RV...
Answered
on Oct 25, 2021
Fix overtemp light on in kipor kde6700ta diessel generator
The overtemp light on the Kipor KDE6700TA diesel generator indicates that the engine is overheating. Here are some steps you can take to try to resolve the issue:
- Turn off the generator immediately and let it cool down. Check the coolant level in the radiator and top it off if it is low. If the coolant level is consistently low, check for leaks in the coolant system and repair them.
- Check the radiator fins for any blockages that may be preventing airflow. Clean the fins using compressed air or a soft brush.
- Check the fan belt tension and replace the belt if it is worn or loose. A loose belt can cause the fan to rotate at a slower speed, reducing the cooling capacity of the radiator.
- Check the thermostat to ensure that it is functioning correctly. If the thermostat is stuck in the closed position, it can cause the engine to overheat.
- Check the water pump to ensure that it is working correctly. A faulty water pump can reduce the flow of coolant through the engine, causing it to overheat.
- If you have tried all the above steps and the overtemp light is still on, it may be necessary to replace the thermostat, water pump, or other cooling system components. It's recommended to contact Kipor customer support or a qualified technician for further assistance.
Once you have resolved the issue, start the generator and let it run for a few minutes to ensure that it is operating at the correct temperature. Keep an eye on the overtemp light to ensure that it does not come back on.
How can fix undercharge code on kipor kde6700ta diessel generator?
The "undercharge" code on a Kipor KDE6700TA diesel generator typically indicates that the battery is not receiving enough charge from the generator's alternator. Here are some steps you can take to address the issue:
- Check the battery: First, check the battery to make sure it is in good condition and fully charged. If the battery is old or damaged, it may not be able to hold a charge even if the alternator is working properly.
- Check the alternator: Use a multimeter to check the alternator's output voltage. The alternator should be producing around 14 volts. If the voltage is lower than this, the alternator may be faulty and in need of repair or replacement.
- Check the wiring: Make sure all wiring connections between the alternator, battery, and generator control unit are clean and tight. Loose or corroded connections can prevent the battery from receiving a full charge.
- Check the voltage regulator: The voltage regulator is responsible for controlling the alternator's output voltage. If the regulator is faulty, it may be allowing too little voltage to reach the battery. Check the voltage regulator with a multimeter and replace it if necessary.
- Check the fuses: Make sure all fuses in the generator's electrical system are in good condition and not blown. A blown fuse can prevent the alternator from charging the battery.
If you are not comfortable performing these steps yourself, it may be best to consult a professional technician to diagnose and repair the issue with your Kipor KDE6700TA diesel generator.
I've got kipor KDE 12sta its crank but not starting
I have a KIPOR 12 Sta that is still virtually brand new, it totally refuses to start. I do not have a compression tester but it certainly feels like it has no compression. has anyone else experienced this problem?
What is the p03 code for kipor generator
P01 oil pressure alarm
P02 frequency alarm
P03 voltage alarm
P04 unit overload alarm
P05 start-up fault alarm
P06 emergency shutdown alarm
P07 charging fault alarm
P08 unit overheating alarm PRE-H unit preheating instruction START unit start-up instruction.
Cummins generator and Perkins generator at website: www.dieselgeneratortech.com. power range is 20kw to 3000kw.
