To connect to a Wi-Fi network with a hidden SSID, select Add Wi-Fi network from the settings. Then manually type in your SSID and password, and select your network security type. Select Save when finished. Now you can browse the web through your Wi-Fi router or connect to other network devices
Wake the Kindle by pressing the button on the bottom edge of the device next to the USB jack. Then after the unit wakes up, navigate to the home screen by pressing the button centrally located on the front of the Kindle below the screen. (I doesn't look like a button, it resembles a grille and consists of 4 black parallel lines.) The home page will pop into view unless you were already there upon waking up.
My Kindle Touch had the same problem but the solution is quite simple:All you have to do is restart your Kindle Touch by tapping Menu then Settings then Menu again, then Restart. Hope it works on yours as it did on mine.
The same way you get any account, you need an email address and some method of payment, assuming you're trying to purchase on amazon.
If you're looking to sell something on amazon, you go to the bottom of any amazon page and click on "sell on amazon" and go from there.
Go to Amazon website
Go to Accounts & Lists
Go to Gift Cards
Go to Add Gift Card
Enter your Card Information
It will show your cards balance
When you purchase an item, select Gift Card as payment method
English only please on this North American website please.
You can just ASK Alexa! Change the Time Format on Your Echo Dot with clock. Say "Change to 24-Hour clock".
Use the Alexa app to change the time format on your device.
Open the Alexa app .
Select Devices .
Go to Echo & Alexa, or to All Devices.
Select your Echo Dot with clock device. This opens device settings.
https://www.lifewire.com > Smart Home > Amazon
Feb 21, 2022 - Restart the Alexa-enabled device. A simple restart is a tried-and-true tech troubleshooting method. Restarting the Echo device may be all you ...
First Swipe downwards from the top side of the screen, second look for settings in the drop down menu and tap on it, third tap on wireless, fourth tap on Bluetooth, then make sure the Bluetooth feature is enabled by flipping the on/off switch to the orange position and lastly if no devices are found then tap scan.
Finally you can enjoy using it now!!!
