20 Most Recent
Brother Entrepreneur Pr 650 Embroidery Machine With Hoops & Frames Questions & Answers
Why will my PR650 not embroider any larger than 6.5 by 7.45?
It may be the number of stitches in the design. Each hoop size has a maximum number of stitches it can stitch, even though the size seems ok. OR, perhaps there is just one stitch that 'infiltrates' the border area that is necessary around each design in the hoop. Check with Brother.com
4/2/2015 7:35:29 PM •
Brother...
Answered
on Apr 02, 2015
Why do I get a Wiper Error every time?
If the thread is not passed through the groove in the thread cutter, the message "wiper error" occurs and needle cannot be threaded. Make sure thread is securely through groove.
If enough thread is not pulled out, the thread cannot be threaded.
Sometimes simply using a different brand of thread will help.
The threader wire is delicate. Get a magnifier glass and examine wire. If not broken, it can be easily adjusted with a fingernail.
Make sure moving parts are free of lint by using canned air.
5/2/2014 8:05:46 PM •
Brother...
Answered
on May 02, 2014
Nesting and tangling
thread nesting in bobbin indicates top tension or miss-threading issue
4/23/2014 3:24:09 PM •
Brother...
Answered
on Apr 23, 2014
Needle threader misses eye of needle 3, how can this be fixed
There is a small wire hook that, when utilized, pokes through the eye of the needle. Several issues can occur. 1) Wire is bent slightly (use fingernail to move the wire to realign with needle) 2) hook is broken on wire (repair shop) 3) needle not fully inserted in slot
4/23/2014 3:09:19 PM •
Brother...
Answered
on Apr 23, 2014
My cricut explore air 2 will not load my mat, what could be the problem?
Cricut Explore Air 2 helps in cutting the beautifully intricate designs using the compatible cutting machines. However, in some situations, you can get the problem where you will not able to use the mat. In this situation, you first make sure you are following the right guide to load the mat, check if the mat is compatible with your Explore Air 2 machine, or your device is not facing any problem.
To get rid of this issue, you have to reset all of your devices and set up the machine once again. Also, check if the mat is not damaged, refer to the Cricut crafting guide for using the mat, use the compatible mat, and more. You can also connect to the Cricut customer support team to get more info from professionals to resolve the issue.
Constraints about making a Jaws of Life model with cardboard, split pins, syringes and plastic tubing.
Question edited for clarity, otherwise this question makes no sense. I presume you mean a MODEL of the Jaws of Life.
Large capacity syringe powering a small capacity syringe with give a significant pressure advantage. The only issue I can think of is the the friction of the secondary piston may be too sticky on the wall of the smaller syringe but if you fill the system with water, you will get true hydraulic results because air can be compressed but water can't
