20 Most Recent Panasonic Lumix DMC-FZ30 Digital Camera Questions & Answers
I have a Panasonic DMC-FZ30PP digital camera. I
Cry. Check with Panny to see if there is any sort of reset that you can perform to the camera to restore operation. If nothing , then your camera has died prematurely. Not a good thing but it happens.
9/9/2017 4:04:03 PM • Panasonic Lumix... • Answered on Sep 09, 2017
2answers
Lumix Panasonic DMC-ZS3. Lost the charger on this
i don't think Panasonic designs its camera to be charged via USB. You will need a actual charger to charge up your camera. this link should help
1/4/2017 3:10:28 AM • Panasonic Lumix... • Answered on Jan 04, 2017
How to repair panasonic lumix fz30 lens?
It doesn't sound like the aperture to me.That would either make it too light or too dark,but I've never heard of it doing both.Double check your settings. I've had problems when I changed a setting,then forgot to reset it back. Also the cameras with a small sensor usually have a small range of f stops,so it shouldn't cause that much of a problem.It could also be the shutter.
11/1/2014 10:20:01 PM • Panasonic Lumix... • Answered on Nov 01, 2014
Display says 'this memory card is protected'
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
10/6/2014 4:38:50 AM • Panasonic Lumix... • Answered on Oct 06, 2014
How to fix slow shutter speed?
When in Any auto mode or P or A your camera automatically will adjust your shutter speed for ambient light conditions. So if your having issues where your camera is choosing to slow a shutter speed and you photos are coming out blurry then there isn't enough light either because other settings in the camera are limiting light or where ever you are taking photos is poorly lit. Setting your ISO Higher should allow the camera to increase the shutter speed, but will often introduce noise to your photos. The more you play with your camera and learn digital photography the more you'll understand how to make your photos the best they possibly can be. For the time being if getting a no blurr shot is key put your camera in S mode which means shutter priority this will allow you to control and lock your shutter speed and set your ISO to auto this will force the ISO and Aperture to change instead of your shutter speed to get a good photo.
7/22/2014 8:56:02 PM • Panasonic Lumix... • Answered on Jul 22, 2014
Change shutter speed
I typed Panasonic Lumix DMC-FZ30 manual into google and up came a pdf i downloaded it and find it hard to follow too. Perhaps change to S (shutter priority) then see what options come up
10/26/2013 6:36:39 PM • Panasonic Lumix... • Answered on Oct 26, 2013
LCD can't view capture photo/pictures
Here is a link where you can get assistance. This issue is not something that can be troubleshot.Click Here
10/23/2013 4:23:50 PM • Panasonic Lumix... • Answered on Oct 23, 2013
3answers
FZ-30 LCD flat ribbon cable broken
Part No is VYQ3473. You can order it directly from Panasonic. It will cost you 29 USD without taxes.
Jimi
10/8/2013 2:01:21 PM • Panasonic Lumix... • Answered on Oct 08, 2013
How do i reset my lumix dmc-fz30 to its original settings
1. Set the mode dial to P2. Press the menu/set button3. Select the setup option4. Scroll through the setup listings until you get to 'reset'5. Select the reset option to reset your camera.
10/30/2012 3:44:58 AM • Panasonic Lumix... • Answered on Oct 30, 2012
I have a Lumix DMC-FZ30 which I bought in late
Hello Frank! Welcome to FixYa!If LCD screen has gone blank but eye piece still works best and as you told that you are unable to read the settings then just follow the given steps to reset the CameraFirst of all, Turn on the camera. When the camera is turned ON, Press MENU button, Then Press right Key. Now you are here on Settings, Now move front dial to switch pages of settings to 3/4. Here you have to keep intention that you have to move front dial to three times because you have yo move to setting page of 3/412_13_2011_11_59_04_am.jpgNow you are here on settings mode where first option as RESET, Now Press right key and the MENU key, It will rest the camera to default settings.12_13_2011_12_02_31_pm.jpgFor more details, i am providing you the manual of Panasonic Lumix DMC-FZ30 Digital Camera,To download manual CLICK HEREIt will help you alot, You need Adobe Reader Software to open this manual, If you don't have download it then you can open this manual. It will provide you in all the operations of Panasonic Lumix DMC-FZ30 Digital Camera.I hope you have clear picture in your mind. Don't hesitate to let me know if you have some confusion.Sir, If you find my service helpful for you the your Rating as FIVE STARS and your Words of appreciation will be esteemed.Thank you for taking my service and for using FixyaConcerned: Muhammad Uzair
12/21/2011 10:26:40 AM • Panasonic Lumix... • Answered on Dec 21, 2011
There is a spot on the picture taken during expose
Possible that the CCD- the charge coupled device which is the optical sensor is damaged as an exposure to very bright light can cause the CCD to burn off. You need to get this confirmed with a consensus, check if the pirtures are having this spot , if so the possibility if high. Otherwise it can be due to fault in the LCD display.
10/1/2011 5:09:05 AM • Panasonic Lumix... • Answered on Oct 01, 2011
I can't to conected to
Having gone two months without a reply to my query, I assume my suggestion to use a card reader solved the problem.
8/29/2011 5:10:02 PM • Panasonic Lumix... • Answered on Aug 29, 2011
I bought a panasonic dmc-fz30 but it did not have
usually the manufacturers have the correct disc. they can send you a new copy if you didnt get the correct disc to begin with. or try their tech support web page.
8/24/2011 12:43:50 AM • Panasonic Lumix... • Answered on Aug 24, 2011
Panasonic Lumix DMC-FZ30 Digital Camera Logo
139 questions posted
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
reset lumix dmc fz30 its original
  • Cameras
