20 Most Recent Sony Cyber-Shot DSC-T3 Digital Camera Questions & Answers
Hi there, I have not used my sony digital camera
This is not 20 months, this is over eight years
1/19/2018 12:22:27 PM • Sony Cyber-Shot... • Answered on Jan 19, 2018
I can't take photos because my lcd its black
Your LCD is dead! Get it replaced (check the price first).
11/6/2015 1:58:07 AM • Sony Cyber-Shot... • Answered on Nov 06, 2015
0answers
manual
16answers
Turn the power off and on again displayed
The Tapping at the back works perfectly for me !! Just tap it a the back a couple of times while switching the camera on xx And job done !!!!
7/8/2013 6:36:01 PM • Sony Cyber-Shot... • Answered on Jul 08, 2013
During power on cycle,lens mechanism resets and move outward.If lens get any external obstruction on it's path of moving outward,it can't position to pre-defined place and an error signal is detected by camera system and further movement is stopped with a error display "Turn the power off and on again".Please read my blog
11/3/2012 11:16:19 AM • Sony Cyber-Shot... • Answered on Nov 03, 2012
Lcd of the camera dsc
I have new LCD panels starting at $29.99 for your camera. I also can repair the camera for you with fast turn around times. Just let us know. [email protected]
7/28/2011 1:31:00 AM • Sony Cyber-Shot... • Answered on Jul 28, 2011
E:61:10
Error code E:61:10 means Zoom operations fault .
Remove the batteries from the camera, wait for 10 minutes, then put them back in and turn the camera on.If this does not work then try the compressed air. With a fine tip blow off the gun, and dry compressed air set the tip between the lens turret and the camera body and turn on the air while moving the tip around a the lens. It should remove all dust and sand. Turn the camera on and it should function as fine.
Secondly give a gentle tap on the sides of the camera and then switch on your camera, you will not get this error message as the internal mechanism which is stuck and causing this problem gets working properly.
Hope this helps.
Shane
3/2/2011 9:31:12 PM • Sony Cyber-Shot... • Answered on Mar 02, 2011
Error E-61-10
E:61:10
3/2/2011 7:50:54 PM • Sony Cyber-Shot... • Answered on Mar 02, 2011
Is there a standing recall
Yes, your camera was recalled. Contact Sony for further instructions.
12/3/2010 8:27:33 PM • Sony Cyber-Shot... • Answered on Dec 03, 2010
2answers
The display screen shows images
This is common problem of ccd imager chip failure in DSC-T3 camera, ccd imager chip replacement will fix this problem and you will get correct live view image in camera mode.
Please check with local camera repair shop for ccd image chip replacement as it is not user level repair and camera will take apart in detail.
Thanks.
11/12/2010 10:36:19 PM • Sony Cyber-Shot... • Answered on Nov 12, 2010
0answers
The LCD-screen seems to work
Try to use a different setting like a bright light setting to see if the apeture is closed down further and brings back focus.
the problem is the auto focus which can be going stray and is not setting right.So take time to shoot with the shutter button down to half to allow it to focus and then once the indication of the focus has confirmed to click.
If not contact Sony service for help.
9/28/2010 10:21:28 AM • Sony Cyber-Shot... • Answered on Sep 28, 2010
Display shows, 'turn the power off and on again'
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
9/11/2010 3:26:41 PM • Sony Cyber-Shot... • Answered on Sep 11, 2010
Sony DSCT33 flash will not work on any settings
You have to get it serviced coz, there are chances that the flash bulb has gone or loose connection...
Thanks....
7/20/2010 2:33:07 PM • Sony Cyber-Shot... • Answered on Jul 20, 2010
When I switch on the camera the LCD screen shows a
Do you have it set for closeups? Mine has one and it's placement made it easy to hit by accident just pulling it out of the case,
So I shoot all the beautiful pictures, including mule deer, in the wenatchee state forest in the mountain range onyl to find out, when I got home and saw them on a larger screen they appeared blurry and smudged.
How far is the image from you? Try a closeup on a flower, if it clears up you know it's switched.
Otherwise clean the lense with a lens kit.
7/14/2010 11:54:43 AM • Sony Cyber-Shot... • Answered on Jul 14, 2010
7answers
Sony cybershot dsc t3
   For all of you who have commen problem in your cameras, That this problem is caused malfunctioning of CCD IMAGER and SONY repair it free of coast. For free of cost replacement of CCD IMAGER please visit your nearest SONY SERVICE CENTERS.
Thanks for using FIXYA!
Take care.
7/2/2010 9:00:37 PM • Sony Cyber-Shot... • Answered on Jul 02, 2010
Flash does not work anymore, why?
I don't know if this is a common fault but the same thing happened to me. Due to the design of the flash unit, only the whole thing can be replaced even if it is a simple repair like the bulb has gone (another con from Sony!). I tired several camera repair shops including Sony and it worked out more cost effecitve to purchase a new camera rather than to get my T3 repaired. I just continued to use the camera without the flash and it worked well enough for that. IMPORTANT NOTE: depending when your one was manufactured, it is not worth spending any money on it in case it develops the well known CCD sensor problem that affects the LCD display. See the link below for more information. It happened to mine just this month and being Sony, unlike the other companies affected, are no longer repairing them for free despite acknowledging there was a fault in the manufacturing of them. Check out: http://www.imaging-resource.com/badccds.html for more information.
HTH
4/8/2010 2:58:54 PM • Sony Cyber-Shot... • Answered on Apr 08, 2010
Sony Cyber-Shot DSC-T3 Digital Camera Logo
77 questions posted
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
error e 61 10
  • Cameras
