20 Most Recent
Sony Cyber-Shot DSC-T1 Digital Camera Questions & Answers
Picture suddenly pink
It is known problem of bad ccd imager in Sony DSC-T1 camera and ccd imager chip will be replaced to get normal live view in camera mode.
Sony will repair it free of cost so click
Sony CCD Imager Support for details.
Thanks.
My screen on my camera is pink. All pictures are PINK!!!
I seem to remember seeing something about this and I think it was on youtube, though at only 6 months old it should still be covered by the warranty and should be returned to the retailer for repair or replacement and no attempt made to repair it or fiddle around with it.
LCD screen is white SONY CYBERSHOT
Good Day, try taking pictures despite no display or LCD is white, connect to PC and observe, if the picture you took can be seen on PC, then your LCD display is defective, hope this will help, thanks
Inverted image
The manual does not tell much about inverting an image. It only says how you can get help on the camera itself when you want to convert a image.
for that clic [Start] -> [All Programs] -> [Image Data Converter] -> [Help] -> [Image Data Converter Ver.4] to get help with the computer program to convert image data, go to the next link.
http://www.sony.co.jp/ids-se/
I hope this is of any help.
For use with compatible battery only????
I've heard of this issue with more than one Sony (seems like there was a post in the forum not long ago with the same issue...). If you've bought a new battery, the problem would appear to be in the camera's power controller. With that in mind, I'm afraid you'll have to decide if the cost of repair is worth it, rather than simply putting the money toward a new camera.
Farid
Says to reinsert memory card & card is in
i have the same problem..
I have a Sony Cybershot DSC T70 and it keeps saying "Reinsert memory stick" whenever I turn on the camera or slide down the camera lid. Also, whenever I try to view the pictures on my laptop it shows "Please reinsert the memory stick" something along those lines. As I have been researching for the solution, I would have to format the memory card. However, I wouldn't want to lose the pictures as I just took many as from the holiday last week. The only problem is the memory card, I tried using another memory card and it works fine with the camera. There is nothing wrong with the camera.\r\nCan someone please help me how to solve the memory stick problem? It would be great. Ty.
Missing dcim.exe file
Hi!
I had same problem and fix it no time. Well this is trick!
virus hide dcim folder and make only visible dcim.exe.
1. so anti-virus will delete that virus "dcim.exe" (or can you)
2. go to start/run and type cmd
3. there you type "attrib -s -h e:dcim"
(assuming that your cam is assigned e:)
Now go to My Computer and DCIM shoud be there!!
I cant see the person im taking a picture of on
This is due to the CCD Image Sensor failure in the Camera.
To confirm the issue, please check if the previously captured images are displaying normally. The previously captured images and icons will get displayed normally if the CCD issue is there in the Camera.
If this happens only with the live view, then try resetting the Camera.
The RESET button is located at the lower right side of the control button. To reset the camera, press the RESET button using a sharp-pointed object.
You may also try power resetting the camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
If the issue is not resolved after resetting, service may be required.
How to delete still images
While viewing the image you want to delete, press the trashcan button. Details are in the "Deleting images" section on page 39 of the manual. If you need a manual, you may download it and more
from here.
