20 Most Recent
Emerson CKS2237 Clock Radio Questions & Answers
The low battery light remains on after I changed the battery,
HelloThere are two possibilities for this fault. The first one is with its battery itself. If the battery did not hold current, in otherwords, it has weak, proper charge both in volts and amperes won't hold on it, and when the device draw current from it while it works, voltage drop will occur, and low voltage indication will be displayed.The second chance is due to the charger circuit inside the radio. If charger circuit do not give proper voltage and current to battery, the battery won't charge to its full capacity. Check it by replacing it with a new battery [batteries] first. If it helps you it's OK. If not, your radio need service, and its charger circuit must be checked well. OK.
I would like to buy one
You can order them directly from emerson.com or go to Walmart, Circuit city. or best buy and find one.
I have a amartset autotime
You can download and print the instruction manual in PDF format by clicking this
link. Adobe PDF Reader is required to view this manual.
Download Adobe ReaderHope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using
FixYa.
Your feedback is important to us.
Kindly rate and
accept the solution if you find it helpful.
Control panel
i dought it, what we use to do is take a thin piece of metal ( end of a 1/4 watt resister) and push it into the plastic tabs of the button
Time is wrong
Sure. p.7 in the user guide:
http://www.sonigem.com/uploaded_files/manual_archive/CKS2237Ceng.pdf
TIme Change
check this link and hopefully it will help - speak to emerson and force them into a solution - you are not alone
http://www.fixya.com/support/t137276-daylight_savings_time_again
if nothing on this link helps then check the rest of the thread by clicking on the link to dddddddddd the user at the top - there is more
Hope this helps - if not please ask again and i will try to find more specific info for your model.
Lost instructions for Emerson
to change the alarm mode setting for alarm 1, hold alm1 setting button and press the alarm mode button until the day indicators show thedesired mode setting. weekday only,weekends only,or everday operation. release the alarm mode and alm 1 setting buttons and the display will return to correct time.
