20 Most Recent
Logitech Wingman Extreme 3D Pro Twist Handle Joystick (GAMELOXT3DPRO) Questions & Answers
Joy stick will only work on the left side .when
Have you run it through its built in calibration utility. If not it is available through the control panel>game controls> calibrate
Or the games you play may have a calibration utility in the options menu.
Too senitive can't control fx9 or fsx
First try the usual suspects. Uninstall *all* game controller software, reboot and install the latest Logitech drivers for your stick. Make sure you've got the latest Vista SP1 + updates. Make sure you're running the latest update of DirectX. Check for patches for your game. Plug the stick into a different port.
Check the physical movement of the stick - any springs feel broken/missing? Tension settings too high or too low? If all those are done, go in to the game controller calibration in Windows and calibrate. Test it - does the stick control the cursor properly? If so, but in-game you have problems, the problem is most likely related to the game code and unless they've released a fix, there's not much you can do.
If the stick has problems with calibration and you've installed any/all updates - likely a defective stick, contact your seller.
Luck!
