20 Most Recent Canon EOS Rebel 2000 35mm SLR Camera Questions & Answers
Camera wont shoot in automatic modes
Have you removed the batteries for a few hours (reset) ? Have you turned the dial around several times (clean contacts) The only other error is the flashing battery light, if it persistes, according to the manual. It's dead as repairs would be pretty expensive against a newer replacement.
2/20/2018 5:25:37 PM • Canon EOS Rebel... • Answered on Feb 20, 2018
Camera shuts off after pressing shutter
Manually turn off the camera, remove the batteries, press the shutter release a few times draining any residual charge. Replace the batteries give it a go. It the issue continues it well may be something wrong with the shutter release.
11/28/2016 3:57:22 AM • Canon EOS Rebel... • Answered on Nov 28, 2016
Turn it off
Turn the command dial to the "L" position to turn off and lock the camera.
11/28/2016 3:45:11 AM • Canon EOS Rebel... • Answered on Nov 28, 2016
How do i replace the battery door? What screws
7/18/2016 7:42:15 PM • Canon EOS Rebel... • Answered on Jul 18, 2016
Need lens (up to 200)
Lens needs are determined by the type of photography one shoots. Example, for my needs I use three prime lens, 35 mm, 50 mm, and 100 mm. Sold all my zoom lens purchased primes. The question is what are you attempting to capture? On a zoom lens look towards a constant aperture, not one when we zoom the aperture changes. Cordially
2/2/2015 6:10:49 PM • Canon EOS Rebel... • Answered on Feb 02, 2015
Film will not fully load
On many of the film Rebels, mine is the T2, the film is completely unwound. As we take pictures the film is rewound in to the film cassette. That is a film safety feature. If the back if the camera accidentally opens we only expose unused frames. The frames we took are safe in the cassette. Cordially
2/2/2015 5:59:18 PM • Canon EOS Rebel... • Answered on Feb 02, 2015
3answers
Need to set to fully automatic setting
The manual for your Canon EOS Rebel 2000 can be found here: http://downloads.canon.com/cpr/software/camera/EOS_Rebel_2000_manual.pdfCheck out page 24 for instructions on shooting in fully automatic mode.Hope that helps,Bax
12/14/2014 5:48:04 AM • Canon EOS Rebel... • Answered on Dec 14, 2014
2answers
How do i turn off
If you need a manual, you can download one from
http://butkus.org/chinon/canon/canon_eos_rebel_2000_300/canon_eos_rebel_2000_300.htm
12/14/2014 5:44:34 AM • Canon EOS Rebel... • Answered on Dec 14, 2014
Camera not working
Hi Jane, When we press the shutter release the mirror flips up after the shutter opens and closes the mirror flips down. When it flips down we then see out the viewfinder. At first blush is sounds as though the mirror flipped up but not back down. Remove the lens look inside the camera press the shutter release what happens? Cordially,
5/26/2014 11:30:41 PM • Canon EOS Rebel... • Answered on May 26, 2014
2answers
Adding a lens to my camera
To be sure you can use the lens, buy a Canon EOS lens. The plastic ones, can be cheap. I bought my last lens 28 - 80 mm, couple of months ago, for 5 dollar. and a working EOS 500 was connected for the same price. (lens and camera are still in good working order) Don't try other brands, because even when you find a convertor, it could be the lens will only work on manual focus.
1/25/2014 5:19:38 PM • Canon EOS Rebel... • Answered on Jan 25, 2014
2answers
28 80 autofocus
Turn the mode dial to the green rectangle for automatic exposure. Set the autofocus switch on the lens to AF for automatic focus.
11/10/2013 1:26:39 PM • Canon EOS Rebel... • Answered on Nov 10, 2013
2answers
Shutting off flash
Yes, but not in the Auto mode, where the camera decides whether or not it needs the flash. Switch to the P mode, which works like Auto except you have control over the flash, exposure, and other factors. See pages 26 and 42 of this manual.
11/5/2013 9:23:32 PM • Canon EOS Rebel... • Answered on Nov 05, 2013
What kind of batteries, and where do i g
The Rebel 2000 uses two CR2 lithium batteries. They should be available at just about any department, electronics, or office-supply store.
11/9/2012 6:08:20 PM • Canon EOS Rebel... • Answered on Nov 09, 2012
Would like a user manual for this camera
You may download a copy of the manual from here.
11/9/2012 6:06:17 PM • Canon EOS Rebel... • Answered on Nov 09, 2012
I just purchased a EOS
Turn the mode dial to the "L" position to turn it off and lock it. Turn the mode dial to any other position to turn it on.
2/18/2012 7:09:04 PM • Canon EOS Rebel... • Answered on Feb 18, 2012
What is the proper way to load the film?
The film canister itself will have a spindle in the middle of it, with it sticking out on one side. Place the canister on the right side, with the spindle pointing upwards. There will be either a spool on the left with a series of pegs on it, or a red marking on the left side for you to place the edge of the film on. (If there are pegs, make sure the sprocket holes on the film fit over them).
3/3/2011 10:26:04 PM • Canon EOS Rebel... • Answered on Mar 03, 2011
Need to upload. download, sideways
You can download the manual from
The webmaster requests a contribution if you find it useful.
12/10/2010 6:57:06 AM • Canon EOS Rebel... • Answered on Dec 10, 2010
I can't change the aperture setting or time value
Try this.
Turn the command dial on the top of the camera to [AV]
Use the [main dial] next to the shutter button to adjust the aperture.
The rear button that is round that is marked 'Av +/-' is the shift button. This controls the exposure compensation.
Could you be turning the wrong wheel?
Hope this helps.
2/25/2010 10:38:25 AM • Canon EOS Rebel... • Answered on Feb 25, 2010
Canon EOS Rebel 2000 35mm SLR Camera Logo
30 questions posted
Top Canon Photography Experts
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Canon Photography Expert? Answer questions, earn points and help others
View Most Popular
Canon Photography
  • Canon Photography
Most Popular Question
need set fully automatic setting
  • Photography
