20 Most Recent Nikon N75 35mm SLR Camera Questions & Answers
Film camera quit working mid-roll.
11/17/2023 5:03:56 AM • Nikon N75 35mm... • Answered on Nov 17, 2023
Hello i was trying to take a picture with my nikon
Your camera is not that old, for a film camera. But they are all electronic. Something in the shutter is bad (mirror going up), and is usually a sign of a dead camera. Repair is impossible and inprobbable. You can pick these up for $40. This mode can use all the newest fancy lenses. I would check the contacts and the battery. If the contacts are clean... it's dead.
2/21/2018 9:25:58 PM • Nikon N75 35mm... • Answered on Feb 21, 2018
What batteries do i use on my nikon n75 camera
2 3v CR2 batteries
11/19/2017 11:28:49 PM • Nikon N75 35mm... • Answered on Nov 19, 2017
My Nikon n75 wont stop flashing error when I try
7/18/2016 5:27:26 PM • Nikon N75 35mm... • Answered on Jul 18, 2016
2answers
Why is film clear after developing? Using bulk load Tmaxx 400
Sounds like the camera isn't working. It would appear the shutter doesn't function because you have no images at all. I would open up the camera and check this. (Empty of film of course).
4/12/2015 2:34:56 PM • Nikon N75 35mm... • Answered on Apr 12, 2015
I just want to know
YES, dont touch those, leave them alone
2/13/2015 4:13:54 AM • Nikon N75 35mm... • Answered on Feb 13, 2015
Instead of loading the film, my camera is
needs repairing at a qualified shop
2/13/2015 4:08:37 AM • Nikon N75 35mm... • Answered on Feb 13, 2015
Nikon N75 battery problem
ebay is your friend
2/13/2015 3:59:58 AM • Nikon N75 35mm... • Answered on Feb 13, 2015
Pictures come out black
did the film advance when you closed the back after placing film into it, what settigns are you using etc ?
2/13/2015 3:49:28 AM • Nikon N75 35mm... • Answered on Feb 13, 2015
Film not going through camera
E indicates empty. try resetting the camera. Pus both the rewind buttons (plus/minus button by release button and bracket button on side of mirror box). Push them at the same time. Let the camera run until it stops (just a few seconds). This resets the camera. Then try loading the film again. Make sure the leading edge of the film isn't bent and is the edge is within the red rectangle under the take up spool. It should then load the film. Note: the N75 pulls all the film out of the cassette and then rewinds it back I one shot at a time until you reach '0'.
8/14/2014 6:34:52 AM • Nikon N75 35mm... • Answered on Aug 14, 2014
What type of battery is used in the Nikon N75 SLR
The N75 takes two CR2 batteries.
5/8/2014 11:47:17 PM • Nikon N75 35mm... • Answered on May 08, 2014
Does nikon n75 work without battery
No.
5/8/2014 4:26:18 AM • Nikon N75 35mm... • Answered on May 08, 2014
manual
When camera is on Autofocus, and Auto exposure
Try resetting the camera by pushing both rewind buttons (two buttons with red rewind symbol), and when the motor stops running open and close the back door then try again. If not it could be as simple as a bad release switch (the switches on the N55 and N75 were garbage) or a electronic problem. Also check to make sure you did not pop the shutter blades out of position when loading film. Remove the lens and gently lift up the mirror with a fingernail and make sure the blades are flat.
10/8/2013 5:56:33 AM • Nikon N75 35mm... • Answered on Oct 08, 2013
My Nikon N75 says error
If the LCD panel shows "E" then the film isn't loaded properly. If the LCD panel shows "ERR" and "E" blinking, then the film is not correctly advanced. If the LCD panel shows a blinking "E" when the exposure meter is turned on, then film remains in the camera after it has been rewound. In all cases, reload film.
If it's not one of those cases, or if the problem persists, please reply to this post giving further details.
8/29/2013 9:22:46 PM • Nikon N75 35mm... • Answered on Aug 29, 2013
manual
Not taking pictures
Could you be a little more specific? Does the camera not turn on? Does it turn on but does nothing when you press the shutter release button? Does it show an error message of any kind? What lens(es) are you using? What exposure mode(s)?
2/24/2013 2:42:15 AM • Nikon N75 35mm... • Answered on Feb 24, 2013
2answers
Need to take a time-delay photo
Press the self-timer button located just right of the LCD control panel and confirm that the one-handed clock shows on the panel. Full details are in the "Self-Timer Operation" section on page 40 of the manual. If you need a manual you may download a copy from here.
9/22/2012 9:03:01 AM • Nikon N75 35mm... • Answered on Sep 22, 2012
2answers
Can't load the film
Turn the camera on. Open the back. Insert film, pull it across to the red mark. Close the back.
Camera should load automatically.
You can get the manual at http://www.butkus.org/chinon/nikon.htm
8/31/2012 2:55:13 PM • Nikon N75 35mm... • Answered on Aug 31, 2012
Nikon N75 35mm SLR Camera Logo
84 questions posted
Top Nikon Photography Experts
Tony Parsons
Tony Parsons
Pallikonda Nisha
Level 1 Expert
Are you a Nikon Photography Expert? Answer questions, earn points and help others
View Most Popular
Nikon Photography
  • Nikon Photography
Most Popular Question
film clear after developing using bulk
  • Photography
