20 Most Recent Microsoft Windows 7 Home Premium X64 Edition 1 Single PC Easy To Create A Home Network Popular Questions & Answers
tip
Set up a new Connection or Network
Creating the Network Opening?the?Networking?and?Sharing?Center. You can launch the Network and Sharing Center in three ways . One way is to click the network icon from the right side of the taskbar, then click Open Network and Sharing Center .
A second (and the quickest) way is to launch the Run window by pressing the Windows key+R, typing control.exe/name?Microsoft.NetworkAndSharingCenter, then clicking OK .
A third way is to choose Control Panel?->?Network And Internet?->?Network And Sharing Center .
The Network and Sharing Center window is split into two areas . On the left side, there is a column containing shortcuts toward tasks, such as managing your wireless networks, changing settings for all network adapters, and changing network sharing settings . On the bottom of the same column, there are shortcuts to the Homegroup settings panel, the Internet Options panel, and the Windows Firewall panel . On the right side, you have basic information about the current network connection and links to several wizards that allow you to change some of your network settings .
Calendar does not schedule
dont' use google calendar, but you may have to use google chrome or other google program to get calendar information. if you used microsoft calendar then it would work with the Microsoft windows software, which is your operating system and not a third party software.
12/27/2015 9:34:09 AM • Microsoft... • Answered on Dec 27, 2015
Widows explorer has stopped working message
Your computer system file's may be corrupted. Use this website links to repair corrupted system files: http://pcsupport.about.com/od/toolsofthetrade/ht/sfc-scannow.htm http://support.microsoft.com/kb/929833
8/13/2014 10:19:22 AM • Microsoft... • Answered on Aug 13, 2014
Windows no longer updates
have you tried deleting the contents windows update directory? ( c:\Windows\SoftwareDistribution\Download )
6/18/2014 4:50:18 PM • Microsoft... • Answered on Jun 18, 2014
New bitlord 2.3.2 is very slow with windows 7 x64.
- Log on as Administrator - Start - run - type gpedit.msc - Expand "local computer policy" - Then expand "administrative templates" - Then expand "network branch" - Highlight the "QoS Packet Scheduler" - On right window double click "limit reservable bandwidth" - On setting tab check the "enabled" - Change "Bandwidth limit %" to 0 - Restart PC Hope so after performing these tips your Bitload download speed will be increased. If Not! Then I would suggest you to download Reginout and optimize your internet speed with simply one click.
2/18/2014 1:30:51 PM • Microsoft... • Answered on Feb 18, 2014
3answers
What is the 500 connect failed?
Good morning Jenna, Majority of the time, a 500 connect fail error is associated with a HTTP Error 500 Internal server error. I am not sure if this is what you are referring to, if not, do let me know and I will address it accordingly. So, what is an error that is presented when the Web Server (the program running the Web Site you are trying to enter) encounters to renders an unexpected problem that prevented it from fulfilling the request by the client (yourself via your web browser i.e. Google Chrome, Internet Explorer and the like). If this is the problem you are having when you attempt to access a website, then there is nothing you can do unless you own the website and have access to the software running it. I hope this helps, Cheers, MarkyyG123
11/13/2019 7:15:43 AM • Microsoft 7... • Answered on Nov 13, 2019
Windows Anytime Upgrade User Interface Has Stopped Working
windows 7 cannot be updated to another type of windows 7 without purchasing a new *********** for that version and then downloading updates. Option2, reinstalling windows using an ultimate disc rather than a basic disk. If you have a key for ultimate you would change your *********** and then manually start update service.
4/18/2019 2:26:28 PM • Microsoft 7... • Answered on Apr 18, 2019
Something strange happened with .psd
Sorry to hear about that. You can try to recover the Photoshop file by using some methods recommended in this guide: 5 Proven Methods to Recover Photoshop Files on Mac and Windows Hope it can help you!
6/21/2018 9:16:01 AM • Microsoft 7... • Answered on Jun 21, 2018
Change language for packard bell
You must have Ultimate or Enterprise edition to go from Polish to English, otherwise you must buy an English version of Windows 7 and re-install the Operating System.
  1. Start -> All Programs --> Windows Update --> Optional Updates.
  2. Open optional Updates and go to the section Windows 7 Language Packs.
  3. Tick the Language Pack you want and hit OK
  4. Proceed with Install Updates
  5. Depiction of Windows 7 downloading a Language Pack
  6. Automatic install initiated after download
How to change the Windows 7 Display Language:
  1. Go to Start -> Control Panel -> Clock, Language, and Region / Change the display language
  2. Switch the display language in the Choose a display language dropdown menu.
  3. Click OK
  4. Log off for the changes to take effect (This will affect only the user profile under which you are currently logged on).
12/15/2017 3:48:42 PM • Microsoft 7... • Answered on Dec 15, 2017
Am having trouble installing Java 7 in Internet Expoler 9. When I do install it, it says that it has been installed, but it doesn't work on tet pages, even in compatibility mode. I'm an expert user, b
I am not an expert user so I don't know much about this but needing to contact a forum to solve a problem I learned the Java programme and Java Script that causes problems when it doesn't work are two different things. Java Script, they told me, is not a standalone programme but a part of the Windows operating system. I can't remember the details but I had to open the control panel and somewhere in there had to "enable script". I hope this helps.
9/14/2017 7:45:37 PM • Microsoft 7... • Answered on Sep 14, 2017
2answers
Windows 7 activation code
Windows 7 product activation code is on the cover of the package of windows 7 its a bunch of characters and numbers in 4 sets of 5 example ( J7PYM-6X6FJ-QRKYT-TW4KF-BY7H9) this is just an example of what to look for dont try to use this it wont work. you get to use the code one time only.
11/25/2016 6:41:31 AM • Microsoft 7... • Answered on Nov 25, 2016
Craig electronics mp3 drivers
You can find a driver for your mp3 player here: http://www.driverguide.com/driver/company/Craig_Electronics/index.html
9/22/2016 12:28:11 AM • Microsoft 7... • Answered on Sep 22, 2016
How to update microsoft intelli-pro
I am assuming you need 64bit software. Click on this link and choose run when asked. You didn't supply very much information so hopefully this is what you need. http://download.cnet.com/Microsoft-IntelliType-Pro-64-bit/3000-2110_4-10966819.html I’m happy to help further over the phone at https://www.6ya.com/expert/adrienne_b03fb46fc6334991
5/15/2016 2:47:03 PM • Microsoft 7... • Answered on May 15, 2016
Cant find my product key , can you give me that.
If you don't mind spending a little money this site: www.mororless.com will be your good choice, the keys in this site are really cheap, you won't miss it.
3/2/2016 7:28:17 AM • Microsoft 7... • Answered on Mar 02, 2016
Cannot review detail on backup xx.v21 files is this possible?
That looks like an obsolete file format. Did you do the backup with "Ghost"? If you can get Ghost 2009 or later, because it has backward compatibility you'll be able to access those .v21 (or .v2i) backups. The software has been taken over by different companies (Symantec, Norton, etc) so try their websites to see if they offer a free utility for .v21 conversion.
1/6/2016 6:26:09 PM • Microsoft 7... • Answered on Jan 06, 2016
Driver lan ultimate vaio 71318l
http://www.sony.co.in/support/download/361067
11/13/2015 3:21:12 PM • Microsoft 7... • Answered on Nov 13, 2015
Brings up the Swipe to Shutdown Screen then goes black
Try holding the button for a shorter period.
5/31/2015 6:15:00 AM • Microsoft 7... • Answered on May 31, 2015
Rremove ask.com from computer
Panel control>Add/remove programs. Then delete all the history of your browser and change the homepage of it too.
3/15/2015 1:45:09 AM • Microsoft 7... • Answered on Mar 15, 2015
How do I delete YouTube?
Go to panel control > add/remove programs and see if there's any program on the list with that name. If there's not, you have not installed any program with that name.
3/15/2015 1:40:56 AM • Microsoft 7... • Answered on Mar 15, 2015
Microsoft Windows 7 Home Premium X64 Edition 1 Single PC Easy To Create A Home Network Popular Logo
5 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
7 Microsoft
  • 7 Microsoft
Most Popular Question
calendar not schedule
  • Computers & Internet
