20 Most Recent Sanyo DS27510 27" TV Questions & Answers
13answers
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
5/3/2019 1:28:44 AM • Sanyo DS27510... • Answered on May 03, 2019
3answers
Converter box
Any Anolog tv should accept a converter box. Just set the tv to channel 3 or 4 to pick up the signal from the converter box.
12/3/2016 2:14:10 AM • Sanyo DS27510... • Answered on Dec 03, 2016
2answers
SANYO MODEL DS27510, CHANNEL DISPLAY IN CORNER WON'T GO AWAY.
If you can program a Comcast remote or another universal remote that has an info key, you can get rid of it. I just succeeded in programming my comcast remote thanks to Dave Taylor:
http://www.askdavetaylor.com/how_to_program_comcast_cable_remote_control.html
Once the remote is programmed, hit the "info" button and watch your frustration disappear!
4/6/2016 11:19:00 PM • Sanyo DS27510... • Answered on Apr 06, 2016
Can I use the service USB port to connect to other devices
No. It is meant for service adjustments only.
8/2/2015 1:47:01 AM • Sanyo DS27510... • Answered on Aug 02, 2015
Is my Sanyo TV repairable or trash?
Fault to the main power supply section circuit. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
5/18/2015 5:38:33 PM • Sanyo DS27510... • Answered on May 18, 2015
I the tv codes for sanyo tv
0173,0118,0138,0182. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electrohelponline.blogspot.com/ Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
2/22/2015 8:29:33 AM • Sanyo DS27510... • Answered on Feb 22, 2015
Ds27425 picture moved forward cannot read channel numbers
Sounds like picture have been shifted horizontally. If you want to adjust the horizontal position, you have to enter its service mode option, and to change the data value there. Contact any service technician. This is a skilled work. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done. NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important. Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
2/14/2015 2:27:35 PM • Sanyo DS27510... • Answered on Feb 14, 2015
Chonghop rm-136 universal tv code
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
12/2/2014 3:27:55 PM • Sanyo DS27510... • Answered on Dec 02, 2014
My Sanyo Ds27910 when searching for channels it says no antenna detected. what does this mean?
If you see thus, check the antenna connection for firmness first. If it seem correct, the tuner to your set is faulty. Does not process the RF signal. There is no repair to this, other than replacement. Contact any service technician to replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
10/24/2014 3:27:48 PM • Sanyo DS27510... • Answered on Oct 24, 2014
0answers
manual
Horizontal AND Vertical Hold Lost
It sounds that the synchronization separator section is faulty. In all modern sets, the section will be a circuit part inside the main IC. Therefore, check out, and replace that IC.
6/28/2013 5:58:54 AM • Sanyo DS27510... • Answered on Jun 28, 2013
2answers
Picture tube has a horizontal line across the
You are experiencing a lack of vertical deflection or vertical collapse. Since it will come back the first thing I would suspect is “ring cracks” in the solder joint in the vertical circuit, mainly the vertical IC. These suspect solder joint can be re-soldered and the television set repaired.
I would suggest that you contact a local servicer. If you are repairing the set yourself, be careful, there is always a risk of shock when dealing with electronics.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post.
If I have helped you, please help me, and rate this suggestion a FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for your support
6/12/2013 9:29:46 AM • Sanyo DS27510... • Answered on Jun 12, 2013
I have a 2002 Sanyo tv what do i need to make it work with out the cable company
do you mean you want to use the tv not through cable program?. ok just remove the cable box then hooked up an air antenna to the RF tuner. then change the settings in the tv select air not cable.
7/28/2012 11:53:46 AM • Sanyo DS27510... • Answered on Jul 28, 2012
2answers
My tv is stuck on the blue screen .
Go push menu button on the front of tv or the right side.Pick the video out,or tv.Or buy a remote.Website 1-800-Remotes factory Original.For the original remote.
6/7/2012 11:42:17 PM • Sanyo DS27510... • Answered on Jun 07, 2012
Change to AV without remote
Not possible unless set has a source or input button on the front or side.
4/30/2012 5:26:23 PM • Sanyo DS27510... • Answered on Apr 30, 2012
I have a 2002 Sanyo 27" TV DS27510, it was working
. There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance. The best way to check for loose connections is to tap lightly when the set is powered on, if there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, and use a good soldering iron to solder all suspected points. Sometimes the fault occurs when the set warms up; if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault. It can also be related to WEAK ELECTROLYTIC capacitors as the value can reduce in time.
11/4/2011 11:14:17 AM • Sanyo DS27510... • Answered on Nov 04, 2011
Sanyo DS27510 27" TV Logo
123 questions posted
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
horizontal vertical hold lost
  • Televison & Video
