20 Most Recent
Samsung DLP HL-P5663W 56" TV Questions & Answers
Samsung DLP TV shuts off
I had the same problem and stumbled on the fix. It seems there is a factory defect. Open the lamp cover and you will probobly notice that the blue shut off switch on the left side is landing on top od the lamp cover. Reach down with a pencil or something and make sure the switch is under the tab on the lamp cover. My 50 DLP has not shut down since I set the switch properly. Free fix... try it.
TINY WHITE SPOTS ARE APPEARING
The DLP chip is failing and will have to be replaced, very expensive. You can call samsung at 1-800-samsung to find the closest service center.
Lost Pin Code
Hi, If you havnt set a personal code it will be the default code and should be in your instruction book. If not try some obviouse ones ie 0000 or 1111 or 1234
Other samsung owners would know the default code so, who do you know who has a Samsung TV?
Can I find out from Samsungs Home page, ie Download instruction book.
Just my thoughts.
Samsung factory reset code
You will need to contact Samsung customer service for this infomation.
You can reach Samsung Customer Support by phone at our toll free number 1-888-987-4357, Monday through Saturday from 7:00 a.m. until 8:00 p.m. Central Time
TV Stand
Start at the link below. Select your country, and then look for customer service, or support. They will tell you who their dealer is in your area for Sanyo parts and service. You will be
guaranteed to
have the proper parts.
http://us.sanyo.com/home.cfm
Jerry G.
