20 Most Recent
Air Conditioning and Heat for Chevrolet Cruze Questions & Answers
Heat blows cold air 2012 chevy cruze
Thermostat is bad and they fail in the 'open' position so the water will circulate and not over heat the engine as id it failed in the 'closed' position. Thus, the water never gets warm enough for the heater core to blow hot air
Passengers side no heating
Either a bad accuator not opening the pass side door under the dash or a bad control unit itself probably not a vacuum leak I really think the 1 st one accuator thanx
My aircon weakend
Possibly needs to be recharged or checked for leaks by a qualified Air con service agent.
My 2011 Cruze"s power to
Even if the problem is as simple as a fuse, fuses don't blow without there being an electrical problem. Take the car to the dealer to be fixed under warranty. Don't attempt any repair yourself or you may void the warranty.
How to reset automatic sliding door on chevy venture van
The rear side door actuator control modules monitor the power sliding door positions at all times. Whenever the battery positive voltage supply to a rear side door actuator control module has been removed or the on-board diagnostics have been activated the power sliding door system(s) must be re-initialized. Re-initialize the right or left power sliding door systems using the following steps:
- Turn the ON/OFF switch for the power sliding door system to be re-initialized to the OFF position.
- Manually open the power sliding door completely.
- Manually close and latch the power sliding door.
- Turn the power sliding door ON/OFF switch to the ON position.
- Open the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
- Close the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
9/9/2022 4:43:40 AM •
Chevrolet...
Answered
on Sep 09, 2022
Check engine light on says p2000 on code reader
The code is: P2000 NOx Trap Efficiency Below Threshold Bank1 and I do not know what that is unless it has something to do with the oxygen supply to the engine. Sorry I am not much help.
10/30/2015 6:24:22 PM •
Chevrolet...
Answered
on Oct 30, 2015
