20 Most Recent Sony Playstation 3 (PS3) Console Questions & Answers
3answers
Ps3 wont play movies
My PS3 met the same issue. But I have tried to convert the Blu-ray to HD video and transferred to PS3 for playback. Maybe you can do this like me. Leawo Blu-ray Ripper is an easy-to-use Blu-ray to PS3 converting tool to help you rip and convert Blu-ray file to PS3 videos in only a few simple clicks. The below step-by-step guide would tell you the details on how to rip and convert Blu-ray to PS3 videos with Leawo Blu-ray to PS3 Converter. Guide on how to convert Blu-ray to PS3 videos: Step 1: Download and install Leawo Blu-ray to PS3 Converter, and then launch it. Step 2: Get source Blu-ray movies ready. Insert Blu-ray disc to the Blu-ray drive, or get source Blu-ray folders ready for loading and converting. Step 3: Load Blu-ray sources Click "Add Blu-ray/DVD" button on the program interface. This Blu-ray to PS3 converter would then guide you to browse source Blu-ray movies for loading. Note: After loading source Blu-ray movies, you could select subtitles and audio tracks, play source Blu-ray movies, edit Blu-ray movies, snap screenshots, etc. Step 4: Do output settings Next to the "Add Blu-ray/DVD" button, click the dropdown box and select "Change". You will then arrive at the Profile setting panel to select output format from "Format" group or "Device" group. Select "MP4? from "Format" or directly choose "PS3? from "Device > Sony". Optional settings: After you've set the output format, click the same dorp-down box and click "Edit" option and then you could adjust video and audio parameters of selected profile, including: video codec, audio codec, bit rate, aspect ratio, frame rate, channel, etc. Step 5: Start converting Blu-ray to PS3 Back to the main program interface, click the green "Convert" button. You could then set an output directory on the right popup sidebar. After setting output dirctory, click the below convert button to let this Blu-ray to PS3 Ripper instantly start converting Blu-ray to PS3 videos. Note: Internet connection is required during the whole conversion. After you convert Blu-ray to PS3 friendlier videos, you can transfer the videos to PS3 and then start to play Blu-ray on PS3 in a indirect way. For details, you can read the extension part. After the conversion is completed, now we should transer Blu-ray movie now in PS3 fridlier video format to PS3 for playing Blu-ray on PS3. Follow the steps below to do so. Here is a simple step-by-step guide for transferring to or watching video files on your PS3 using a USB flash drive or an external hard drive. Step 1: Plug a USB flash drive or an external hard drive into your computer and copy over the converted video files that you want to watch on your PS3. Step 2: After the copying process is done, pull out the USB flash drive or the external hard drive from your computer and then plug it into one of the USB ports on the PS3. Step 3: Navigate to "Video" on the PS3 XMB menu and find your device, hit triangle to view all contents and select the file you want and either copy it to the PS3 hard drive or just play it directly from the connected device. By following the guidance above, you can achieve your goal of more safely and conveniently playing Blu-ray on PS3 or watching Blu-ray on PS3 for protecting either PS3 Blu-ray drive or your precious Blu-ray discs from being scratched. For more details, check: Direct and Indirect Ways to Play Blu-Ray on PS3 play-blu-ray-on-ps3-sc0argftqvwjsqq3lwa1qgma-5-0_1.jpg
4/3/2024 7:21:58 AM • Sony Playstation... • Answered on Apr 03, 2024
5answers
Ps3 error 8011012f, How do
I had the same message until i typed the password of 0000 when it prompted me to type a password.
3/26/2024 2:11:34 PM • Sony Playstation... • Answered on Mar 26, 2024
3answers
Hello. sorry for disturbing but my game naruto
Hello tanoeluc23
Whenever a PS2 game is run in backward compatibility mode, there's always a chance of a problem arising.
There were/are problems with this series of games running on the PS3. You'll have to wait until either Sony or the games publisher release an update to rectify the situation.
ajblaj
1/27/2024 4:50:14 PM • Sony Playstation... • Answered on Jan 27, 2024
BOUGHT A used ps3 need to delete old user and make new user? How do i do that.
1. Start your ps3 2. Press triangle on the old profile 3. Delete the profile 4. When the old profile is deleted, it will say make a new profile
10/28/2023 12:12:23 PM • Sony Playstation... • Answered on Oct 28, 2023
2answers
I was trying to import
it's a copyright protection error... happens with some CD's... try copying the songs to a PC and use a flash drive to transfer, or copy to the PC and burn to a new disk
10/22/2023 1:38:41 AM • Sony Playstation... • Answered on Oct 22, 2023
3answers
When playing Red Dead Redemption
If a game freezes, then the problem is usually due to the PS3 overheating. The PS3 needs good airflow through the vents so make sure that you don't put it in a corner or in a place where the hot air won't linger around for long like near a window. Also, don't play for too long; give your PS3 a break every once in a while (1 minute breaks don't count) :)
10/16/2023 3:41:31 AM • Sony Playstation... • Answered on Oct 16, 2023
I can hear the music but people speaking sounds like they're faint and echoed
If you can hear the music in your PlayStation 3 (PS3) but people speaking sounds faint and echoed, there are a few things you can try to improve the sound quality: 1. Adjust the audio settings: Go to the PS3 menu and select "Settings" > "Sound Settings" > "Audio Output Settings." Choose the appropriate audio output settings for your system and TV or monitor, and make sure that the correct input channel is selected. 2. Check your connections: Make sure that all of your cables are securely connected to the PS3 and the TV or monitor. If the cables are loose, this can cause poor sound quality. 3. Check the game or movie settings: If you are playing a game or watching a movie, check the audio settings within the game or movie to ensure that the sound is optimized for your TV or monitor. 4. Adjust your TV or monitor settings: If the sound quality is still poor, adjust your TV or monitor settings. You may need to adjust the bass, treble, and other audio settings to improve the sound quality. 5. Use headphones: If none of the above solutions work, consider using headphones to listen to the sound from your PS3. This can provide better sound quality and reduce background noise and echoes. If you continue to experience problems with the sound quality on your PS3, you may need to contact Sony customer support for further assistance or repair. Take care and have a great day! -Alex
4/26/2023 5:36:59 AM • Sony Playstation... • Answered on Apr 26, 2023
3answers
My PS3 have error code 8002f334
I've seen this error code going around for the older PS3's. From what I can gather, it's a HDD issue that can't be cured easily. Here are the steps to take that I found, that seem to work for all PS3 systems.
  • take out the hard drive
  • connect hard drive to pc (running windows 7 64bit, but any windows os should work without other software)
  • open up disk management - in win7 it asked me to make a master boot record, so I did.
  • format in NTSF - that's right, NTSF - don't use quick format
  • shut down pc, take out hd, take usb drive too
  • put hd back in ps3, put usb stick in ps3
  • boot ps3
  • a screen will pop-up saying the hard disk have to be formatted
  • hold start + Select for 5 sec.
  • After formatting the system will restart and the update will start installing
  • configure your ps3 setup - done
  • Remember to get the latest firmware from SONY onto the USB drive.
4/1/2023 12:30:38 AM • Sony Playstation... • Answered on Apr 01, 2023
4answers
HDMI causes red lines (static?) on screen
im having the same problem to fix it i unhook my cable box (the video cables and the hdmi inputs to the tv) this stops the lines--try just the ps3 hooked to the tv and no other devices this should solve the problem--must be getting interference from some device
2/17/2023 2:19:51 AM • Sony Playstation... • Answered on Feb 17, 2023
2answers
Hey can you please help me repair my ps3
it may be the type of system because the kind I might get is
exspensive
12/5/2022 10:07:42 AM • Sony Playstation... • Answered on Dec 05, 2022
2answers
Can i use PS3 europe in the philippine, that have
Yes, you can use European PS3 in Philippine, only if you don't play any region-locked DVD or Blu-ray. Also, if you want to watch some Pinoy movies on your PS3, here is a post including many sites for free download: https://www.leawo.org/entips/pinoy-movies-download-1409.html?fx=1409
12/2/2022 2:26:57 AM • Sony Playstation... • Answered on Dec 02, 2022
2answers
How much does it cost to repair a ps3 with a
If your not technically inclined, Sony will charge $149 as according to the people of this board:
http://boardsus.playstation.com/playstation/board/message?board.id=ps3&thread.id=1967987
or according to this page about $100:
http://answers.yahoo.com/question/index?qid=20081027082956AAq2HA3
My guess would be to take it to a local repair shop near you as they may not charge as much. The blinking lights that you are referring to usually mean the power supply has gone bad and power supplies don't run much. This guy thru Ebay has the power supplies for $50 and thats with free shipping. Don't know the guy personally but $50 seems reasonable if you know how to get into your ps3 and take out the old power supply and put the new one in.
http://cgi.ebay.com/PLAYSTATION-3-PS3-POWER-SUPPLY-APS-226-OR-ZSSR5391A_W0QQitemZ300319803458QQcmdZViewItemQQptZVideo_Games?hash=item45ec748842&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1234|240%3A1308|301%3A1|293%3A1|294%3A50
Really its up to you. Its not hard taking the ps3 apart. Just taking a few screws out from the bottom and then a few from the top and taking the top cover off and exposing the ps3.
11/25/2022 9:52:29 AM • Sony Playstation... • Answered on Nov 25, 2022
4answers
How to remove disk from playstation3 console that will not turn on
1. First shut down the system by flipping the power switch in the back off. 2. Hold down the eject disc button. 3. While still holding down the eject button, flip the power switch to turn back on your PS3. 4. When the green light comes on, wait a few seconds then tap the eject button a couple times. The fan will run on full power and the disc will eject.
11/2/2022 11:15:58 AM • Sony Playstation... • Answered on Nov 02, 2022
"an error occurred during download operation" ps3 when i try to update ..please help
This Error code means there is a Network/Router error, try this to see if it corrects the problem, depending of on if you have a wired or wireless connection 1. WIRED CONNECTION > CUSTOM > MANUAL SETTINGS > AUTO DETECT > AUTOMATIC > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X 2. WIRELESS > ENTER MANUALLY > ( ENTER SSID OR CONTINUE ) > ( CHOOSE SECURITY OR CONTINUE ) > CUSTOM > AUTO > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X
10/25/2022 1:11:21 PM • Sony Playstation... • Answered on Oct 25, 2022
24answers
Ps3 not reading disk
i had the same problem. just fone sony tell them wats up and they will arrange 2 pick up ur faulty ps3 and replace it there and then!!
here is the number for sony if it has any help:
08705 99 88 77
10/4/2022 9:47:11 PM • Sony Playstation... • Answered on Oct 04, 2022
7answers
Unlock Uk ps3 to play region free blu ray dvd's
repair hack cheat and unlock ps3 yourself in less than 1 hour
http://repair-ps3.co.cc
10/4/2022 9:46:09 PM • Sony Playstation... • Answered on Oct 04, 2022
27answers
My PS3's hard disk file system is corrupted
This happened to my husbands PS3 also. He put it into another PS3 and reformatted it and then when he got home and put it back into his it asked him to reformat again and this did the trick. It's been working ever since. He called Sony and they wanted him to send back his hard drive and they would either fix or send him a "new" refurbished one for $150. I don't think so!!
10/4/2022 9:44:19 PM • Sony Playstation... • Answered on Oct 04, 2022
19answers
Need help with ps3 internet hook up
The ps3 wifi is very finicky --
While the ps3 scans for a hotspot turn the router off then on so the router aquires the ps3.
Goto settings
Goto network settings
Goto network connection, select enable
Goto Internet connection settings just below internet connection-
Push yes when it says you may be disconnected
Select wired or wireless
For wireless use scan or enter manually
Follow on screen instructions.
Once that is set up return to main menu and go to network near the right
Then once in the internet browser press triangle and goto file and enter the internet address you would like visit.
If all else fail use the ethernet cable to attach it to your laptop. Then run network setup on the laptop and add the ps3.
10/4/2022 9:43:16 PM • Sony Playstation... • Answered on Oct 04, 2022
41answers
PS3 says DNS error (80710102) when i try to connect to the internet with a wired connection
for mine i tried other fixes and they didn't work. Turns our my router had enabled security but the PS3 had forgotten the password (WEP key).
I turned off the WEP on my router and the PS3 suddenly found its connection.
To say I was getting stressed is an understatement, Sony should put something on their website, it seems like a really commonm problem to which people have no clear route to solution.
10/4/2022 9:40:21 PM • Sony Playstation... • Answered on Oct 04, 2022
43answers
Playstation 3 won't play games, dvd's or blueray movies
this has happen to me!! and i end up buying another ps3 and it end up the same!!! i fix both of them!!! and about over 200 consols with the same problem!!! this is what u do! you connect your control direct to your ps3. and then you hold the power button for 5 seconds!! the system will turn on!!!remove your finger for a second and hold the power button till you hear 2beeps then remove your finger and the system will shut off!! this is a manuel reset!!! the system will turn back on!! asking u to connect your controller!! you already have it connected. then it will give you about 6 options!! you will choose RESTORE FILES!!! your system will check for your system defaults!! then it will tell you that you have corrupted files!! and proceed with it!!! it will fix if you have problems with your controls,if it doesnt play games,blue ray,if it freeze, system shutting off,icon problems,only playing sertting games or movies!!! if you have problems or any question feel free to ask!! i know is fustrating!!!
10/4/2022 9:39:22 PM • Sony Playstation... • Answered on Oct 04, 2022
Sony Playstation 3 (PS3) Console Logo
31,934 questions posted
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
PlayStation Sony
  • PlayStation Sony
Most Popular Question
use ps3 europe in philippine
  • Video Game Consoles & Games
