20 Most Recent Sigma Powers Inc Rural King 6,500 Watt Electric Start Portable Generator 6500E Questions & Answers
2answers
I have a rural king generator 6500 E It starts fine but after a few Minutes it dies?
It sounds like it is starving for fuel. You probably need to rebuild the carb.
2/25/2018 9:58:58 AM • Sigma Powers Inc... • Answered on Feb 25, 2018
Putting new gas line on as I have had lots of trouble with gas leaks. anyway gasket fell off of carb. can you send a pic of how it goes on? the gasket that is
Mike, Sorry to hear the carb is leaking. This happens when the Carb Float Needle gets stuck and is easy to rectify. If you watch this video on YouTube it will show you how to free up the Float Needle. It is the same procedure on all Carbs: https://www.youtube.com/watch?v=7LrBmeBcVnA
12/20/2016 9:48:36 AM • Sigma Powers Inc... • Answered on Dec 20, 2016
2answers
I Have a Rural King Generator it starts Fine but only runs a few minutes and it shuts off
Make sure the gas is fresh. Also, take off the carb bowl and look for signs of gumming. If there is gooey stuff in the bowl, then the carb needs to be cleaned.
12/14/2014 10:57:46 PM • Sigma Powers Inc... • Answered on Dec 14, 2014
Sigma 6500E generator
First verify that the breaker for the outlets is not tripped and make sure that the generator is running at full operating speed. let it run for 5-10 minutes and check for output power. If there is nothing, there are two possible problems. One could be that the automatic voltage regulator is bad. The other is that the field needs to be flashed - a high possibility if the generator has not been run in a long time. There are many videos on the internet that show you how to solve both of these problems. Just do a search for No output from a portable power generator.
6/24/2014 11:23:13 AM • Sigma Powers Inc... • Answered on Jun 24, 2014
0answers
Need a sigma 6500e assembly diagram
I just purchased a Sigma 6500E generator, there was no instruction manual with it. Did get in stalled, but couldn't find out where to connect the battery cable, also there was nothing about the engine at all. Does the battery get charged when the generator is running ? I would hope that information is available for this unit. thank you
3/1/2014 5:21:48 AM • Sigma Powers Inc... • Answered on Mar 01, 2014
0answers
Gascap
Be the first to answer 1/16/2014 3:45:19 AM • Sigma Powers Inc... • Posted on Jan 16, 2014Be the first to answer
0answers
Manual for scorpion sl2800 generator
Yes
4/9/2024 2:32:16 AM • Electrical... • Answered on Apr 09, 2024
2answers
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/ Quoting from link above: "Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error : * Press the Back arrow on the keypad - this step is to refresh the UIU ( the device) * Type # 75 # - this is to check the signal strength If it does not go back to the normal display *Type # 80 # - this is to refresh the meter Then lastly you can repair the meter and the UIU by # 36 # The above steps will work better if you are outside the house because the meters uses the radio frequency connection The above error will occur in instances of bad weather conditions or if there is load shedding or power failure If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again. SOLVED: Pole meter conlog rf con meter keep on freezing ... Jan. 10, 2017 Meter reading shows rF CON instead of units available - Fixya Jun. 24, 2018 SOLVED: Good day my conlog ip54 elecricity meter showd ... Oct. 6, 2018 SOLVED: Rf con error - Fixya Jun. 20, 2020 More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ... How Do I Load The Activation Token On My Conlog Prepaid ... Mar. 17, 2020 I Need A Technician To Fix This... - Nairaland / General - Nigeria Jul. 22, 2019 I Need Number Codes To Reset Memmcol Prepaid Meter ... Jan. 11, 2019 More results from www.nairaland.com
3/24/2024 3:42:46 AM • Electrical... • Answered on Mar 24, 2024
Wiring 3 lights 3 separate switches
Consult a qualified electrician.
3/23/2024 7:13:23 AM • Electrical... • Answered on Mar 23, 2024
Kawasaki GA1400A Generator. It starts fine, 12 volts okay, but no 230 volts.
Question edited for clarity. Question moved from Motorcycles to Generators category. Some help in the link, but not as much as I would like https://www.google.com/search?q=Kawasaki+GA1400A+no+230+volts+output ..
2/11/2024 5:52:06 AM • Electrical... • Answered on Feb 11, 2024
GE outdoor 200A fusible disconnect can not stay on position, how to fix this issue
It has a cantilever snap action. Either the spring has detached, broken, disabled or unit is otherwise damaged. Heat, water, rodent, etc damage. Replacing the unit is most likely your only option.
2/9/2024 12:37:45 PM • Electrical... • Answered on Feb 09, 2024
Sigma Powers Inc Rural King 6,500 Watt Electric Start Portable Generator 6500E Logo
13 questions posted
Top Sigma Powers Inc Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you a Sigma Powers Inc Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sigma Powers Inc Electrical Supplies
Most Popular Question
putting new gas line as lots trouble gas
  • Electrical Supplies
