20 Most Recent
Activision Blur Questions & Answers
Serial code
I'm Sorry but legally we are not allowed to redistribute or give people serial codes to things as the serial code proves that you own the software and paid for it giving you a code is basically either buying it for you or illegally giving it to you i hope that you understand
Blur serial code
I used to use crackdownloader to find serials but it is getting old and can't find any newer serials. I just researched and got graagle and it can't find blur. I tried to search activision and it found 9 serials but not for blur. Sorry
Blur "is not a valid 32 application" fix....
I just have upgrade my window (install new window 7 ultimate) and I can't play Blur anymore, It says that "Blur is not valid a 32 application", even I reinstall and activate Blur again but It still don't allow me to launch the game, any help please !!!!
Serial number game illegal
DO NOT INSTALL! Downloading games illegally is (a) not supporting developers and (b) the people that crack games usually have hidden programs i.e keyloggers and such. I learnt this the hard way. Just buy a copy.
I am having a problem.
Direct3D 6? Wow, the game must be way older than your computer. You probably installed DirectX 10 or later. There were major changes after DirectX 9. The software routines to manage graphics hardware acceleration through DirectX 10 or newer are probably very different from DirectX 6, so the game's graphic controller interface can't find them.
Try going into the game properties (right-click on the main executable file and select Properties from the pop-up menu).
Set it to run in XP compatibility mode and see what happens.
Check to see if the game has the option to run without hardware acceleration. If this provides acceptable performance, that is your answer.
If necessary (and if Microsoft still makes it available), try installing DirectX 6. Vista may snag on it and make you remove it and reinstall a newer version, but it's worth a shot if the other fixes don't work.
