20 Most Recent Mtd Drive Belt 42" Questions & Answers
I need a diagram of how to replace the belt on MTD RH125/92B
PartsTreeRepairClinic may have a video
3/6/2018 3:07:57 PM • Mtd Drive Belt... • Answered on Mar 06, 2018
2answers
Looking for the manual or guide to installing the
Try PartsTreeRepairClinic
2/13/2018 1:31:58 AM • Mtd Drive Belt... • Answered on Feb 13, 2018
I just changed the drive belt on my 2007 mtd yardman and now I have very little speedand suggestions to hte problem
are you sure that you have the right belt if you do i have no idea but make sure the belt is right
9/10/2017 2:45:30 PM • Mtd Drive Belt... • Answered on Sep 10, 2017
Want to eliminate AC compressor from belt
Some vehicles that have A/C as optional had pulley arrangements that allowed for with/without A/C routing. You just needed a shorter belt. Newer vehicles all seem to have A/C standard and so it is more difficult to bypass the compressor on many of these. If you provide the manufacturer, year, model, engine size, and 2WD/4WD/AWD, we can research and address the question better.
11/4/2015 5:32:08 PM • Mtd Drive Belt... • Answered on Nov 04, 2015
Belt size for 42 inch cut ,drive belt?
Go to lowes wedsite Enter drive belt MTD 42
11/3/2015 12:11:46 AM • Mtd Drive Belt... • Answered on Nov 03, 2015
I changed the belts on my MTD 42riding mower. When I depress the clutch pedal & put it in gear it takes off. The only way you can stop is to turn it off.
I an wondering if you have the wrong drive belt. I did this myself and the belt was too tight so when I started the tractor up it put me into a ditch full of water. I had to get the right belt. My replacement was only one quarter inch shorter but would not work.
10/31/2015 7:23:08 PM • Mtd Drive Belt... • Answered on Oct 31, 2015
My MTD riding mower is
normally sign of a failing hydrostatic transmission. if your mower has one, start looking for a new one, mower that is as a new tranny will cost more than a new mower.
8/12/2015 1:11:03 AM • Mtd Drive Belt... • Answered on Aug 12, 2015
How doyou change the drive belt on a task force 2000 riding lawn mower?
there mite be diagram on deck look in owners manual or to jackssmallengines.com he may have diagram or manual
2/12/2015 5:40:55 PM • Mtd Drive Belt... • Answered on Feb 12, 2015
I need a diagram to replace a deck cable on a mtd yardman tractor
Go to MTD website and download the manual for your machine.
1/7/2015 11:29:25 PM • Mtd Drive Belt... • Answered on Jan 07, 2015
Need the mower deck belt size for a allis chalmers t-811 lawn mower
42" deck 1/2 x 120 P/N 1668066SM 48" deck 1/2 x 126 P/N 1703466SM
10/20/2014 6:39:13 PM • Mtd Drive Belt... • Answered on Oct 20, 2014
My 42 mtd is chugging when i put in forward
Don't know if this is your problem but here is what happened to mine.. My lawn tractor is about 10 years old. It has been generally quite reliable. However I was mowing with it one day and after 15 minutes or so it started hunting and then quit. After a few minutes it restarted and ran for a further 15 minutes. This time I disconnected the gas line after the fuel filter and nothing came out. I removed the filter and blew through it and it was clear. But no gas came out of the gas line till I pointed it downward then got a good flow. Reassembled and drove for a few more minutes and quit again. Checked the spark - good. I removed the gas line after the filter again intending to blow some air into the carburetor to clear any obstacles there except - no gas from the line. I removed the gas cap and out came the gas. The problem was the pinhole vent on the cap was plugged and not allowing air into the tank to replace the gas being consumed. Cleared that and solved the problem! Hope it helps someone else save $150 or whatever it costs to take it into the shop!
10/8/2014 9:06:31 PM • Mtd Drive Belt... • Answered on Oct 08, 2014
What size for a 611 deutz allis 42 in deck
Go to simpletractors.com they may have the answer for you !
9/21/2014 2:17:54 PM • Mtd Drive Belt... • Answered on Sep 21, 2014
Where does the spring hook for blade engage cable
On mower deck.
9/5/2014 1:54:00 AM • Mtd Drive Belt... • Answered on Sep 05, 2014
Why doesn't the shifter on my 42"mtd mower not effect the trans?
If the tractor has a hydro-static transmission. There is a rod at the back to make tractor roll easy for pushing. Rod out for neutral.Rod in for drive ingaged.
9/5/2014 12:59:14 AM • Mtd Drive Belt... • Answered on Sep 05, 2014
How do i change the drive belt on my L 130 ?
Remove the mower deck first. Remove the electric PTO clutch assy. Disconnect the clutch spring as to remove the tension on the drive belt. From there it a simple matter of removing the belt from the pulleys. Depending the belt retainers you need to them too.
8/2/2014 3:02:08 PM • Mtd Drive Belt... • Answered on Aug 02, 2014
Cub cadet belt diagram
YouTube video on replacement at: https://www.youtube.com/watch?v=rrxE1SKacxo
7/20/2014 6:05:10 AM • Mtd Drive Belt... • Answered on Jul 20, 2014
How do you remove a field assembly with brake off of a 721d grasshopper lawn mower
you question makes no sense to me. ask it a different way or tell us what your trying to do. Are you trying to move the tractor ???
7/13/2014 12:15:16 PM • Mtd Drive Belt... • Answered on Jul 13, 2014
MTD starter ingages but wont turn motor
HAVE REPLACED THE BATTREY LATE LEY IF SO SOUNDS LIKE THE CABELS ARE BACK WARDS CK IF THAY ARE IT WILL SPIN THE STARTER THE WRONG WAY
11/11/2013 2:25:46 AM • Mtd Drive Belt... • Answered on Nov 11, 2013
Mtd Drive Belt 42" Logo
84 questions posted
Top Mtd Garden Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
john h
Are you a Mtd Garden Expert? Answer questions, earn points and help others
View Most Popular
Mtd Garden
  • Mtd Garden
Most Popular Question
changed belts mtd 42riding mower when
  • Garden
