20 Most Recent Toro 52" 27hp Z Master Zero Turn Lawn Mower Questions & Answers
Trying to fix steering on a toro 360 quad steer, cant get it to track strait from front to back wheels.
If you're having trouble getting the Toro 360 quad steer to track straight from front to back wheels, there are a few potential issues that could be causing the problem:
- Wheel alignment: If the front and back wheels are not properly aligned, this can cause the steering to be off. Make sure to check the alignment of both the front and back wheels, and adjust them as necessary.
- Tire pressure: Uneven tire pressure can also cause the steering to be off. Make sure all tires are inflated to the recommended pressure.
- Steering linkage: Check the steering linkage for any signs of wear or damage. Replace any worn or damaged parts as necessary.
- Steering gear: The steering gear may need to be adjusted or replaced if it is causing the steering to be off.
- Suspension: Issues with the suspension system can also affect the steering. Make sure to check the suspension for any damage or wear, and replace any damaged parts.
If you're still having trouble getting the Toro 360 quad steer to track straight, it may be a good idea to take it to a professional mechanic for further inspection and proper fixing.
3/14/2023 3:46:23 PM • Toro 52" 27hp Z... • Answered on Mar 14, 2023
2answers
I have a 52 Toro Z Master 2000 series that will not start.52” Z-Master 2000 zero-turn mower.
not a car or truck but is mower moved yah. 11.9 is no good. batter bad or discharged., so charge it to 12.6vdc rested volts . if you jumper cable start it like car ,bingo it run if it will not charge the battery is EOL, END OF LIFE> toasted. I do winter overs with a float changer full time and the battery goes 5 seasons not just 1
12/14/2022 12:32:54 AM • Toro 52" 27hp Z... • Answered on Dec 14, 2022
Customer brought in zero turn mower, not charging, customer replaced stator, regulator and flywheel, still does not charge
Never trust the customers work. go thru all the steps for testing the charging system.
5/15/2019 4:50:04 PM • Toro 52" 27hp Z... • Answered on May 15, 2019
Changed filter, oil, full of gas checked gas flow everything is good , when I start m lawn mower it runs , when I engage my pto and start mowing for about 5 minutes it just quits
if this is got the 27 hp kohler engine, I know exactly whats wrong with it , due to grass and engine oil building up in a short time under cylinder heads , it actually makes a tight ball of grass and stuff there !! this holds the engine heat and ruins the ign module that's just above it there , I put two on in one season ( tractor runs 6-10 hrs day 6 days a week ) I finally gave up I bought a Kawasaki 27 hp twin and installed it , now its run for two seasons and no problems engaging the pto has nothing to do with it , it would cut off if you just drove it around for 15 minutes
9/18/2015 11:29:42 PM • Toro 52" 27hp Z... • Answered on Sep 18, 2015
2answers
Mower was running shut off now does nothing when i turn key
If electric start check for low battery or loose battery cables. Could be a bad starter.
3/23/2015 2:46:46 PM • Toro 52" 27hp Z... • Answered on Mar 23, 2015
Electric clutch pto. wire pulled out of assymbly.
It may not just slide off , but should be able to come off with hand tools.
10/15/2014 7:07:16 PM • Toro 52" 27hp Z... • Answered on Oct 15, 2014
What is Kohler command in the clutch assembly
what is question dont undrestand
9/4/2014 1:07:50 AM • Toro 52" 27hp Z... • Answered on Sep 04, 2014
Why does Toro z150 ( 2001) stall when I release brake?
you need a govenor adjustment for load for engine
8/28/2014 1:44:45 AM • Toro 52" 27hp Z... • Answered on Aug 28, 2014
Backfires when I ingage the blades
one of your valves is not seating
8/18/2014 12:00:59 AM • Toro 52" 27hp Z... • Answered on Aug 18, 2014
How to remove the clutch
Unplug clutch wire and remove bolt from clutch. Make sure you install it the same way it came off. Should have a notch in clutch that stops it from spinning around and ripping wire out of the clutch.
8/14/2014 6:08:31 PM • Toro 52" 27hp Z... • Answered on Aug 14, 2014
How to remove starter on Toro Z master with kohler 26 HP engine?
First disconnect the battery. Then unhook the wires from the starter should be one or two wires. Remove the bolts from the starter two or three bolts.
7/25/2014 3:24:53 PM • Toro 52" 27hp Z... • Answered on Jul 25, 2014
Replacing deck belt
Make sure that blades are not engaged which will cause the pulley to be out further making the belt too tight for install. There may also be a tensioner pulley that may need to be released.
7/25/2014 7:11:49 AM • Toro 52" 27hp Z... • Answered on Jul 25, 2014
0answers
Spindle
Be the first to answer 6/30/2014 3:43:52 AM • Toro 52" 27hp Z... • Posted on Jun 30, 2014Be the first to answer
Mower wont turnover at key switch
Mower has multiple safety switches, seat,&hydraulics, also a bad PTO switch will cause them not to start.
6/20/2014 12:05:01 PM • Toro 52" 27hp Z... • Answered on Jun 20, 2014
Toro 52" 27hp Z Master Zero Turn Lawn Mower Logo
103 questions posted
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
View Most Popular
Toro Garden
  • Toro Garden
Most Popular Question
52 toro z master 2000 series cannot get
  • Garden
