20 Most Recent Toro Power Lawn Mower Questions & Answers
Toro 22" Recycler Vibration Problem
Disconnect the spark plug for safety reasons. Turn the mower on it's side, carburetor up. Slowly turn the blade by hand. You should notice if it is bent. Remove the blade. It is usually a 9/16 in bolt. Use a straight edge to determine if the cranksaht is bent. If the deck is good, you can find a used engine that bolts on. Otherwise you can use it for parts.
9/9/2022 3:23:22 AM • Toro Power Lawn... • Answered on Sep 09, 2022
2answers
Toro Timecutter rapid clicking when starting.
If the rapid clicking is coming from the solenoid or starter, it sounds like your ignition key switch is broken internally. Something is making and breaking the starter connection due to the vibration of the engine running.
6/24/2021 11:37:07 PM • Toro Power Lawn... • Answered on Jun 24, 2021
2answers
2answers
Mower won't start spark plug turns black
Black carbon fouling on the plug is a sign of the engine running too rich, start by replacing the air filter and plug and try again.
5/2/2018 6:14:34 PM • Toro Power Lawn... • Answered on May 02, 2018
2007 workman 1100 jumps out of gear
check the spring on the shifter
2/7/2018 3:02:23 PM • Toro Power Lawn... • Answered on Feb 07, 2018
How is the traction cable adjusted on Toro Model 20027, Serial # 20005663. I'm replacing the cable and the new one is slightly different from the old one, but the Toro shop tells me it's the proper re
There is a large black plastic nut at the end where the cable attaches to the mower transmission. Turning it clockwise tightens the cable (engaging traction bar is tighter) and counter-clockwise is loosening the drive. If the cable is a little too long, you have to tighten it more.
9/28/2017 2:35:27 AM • Toro Power Lawn... • Answered on Sep 28, 2017
My toro super recycler bogs down while mowing. I have fresh gas, just changed the oil and filter. Any suggestions?
check and be sure the blades are sharp. if the blade gets a rounded edge it wont cut properly and will bog down trying to cut.
8/15/2016 10:30:38 PM • Toro Power Lawn... • Answered on Aug 15, 2016
Gov and throttle linkage
gov. rod hooks to the hole in the top of the butterfly. the spring hooks to the carb and the front of the engine on the metal tab. 26256609-jg13hxxvhk0jaxwe0yezbjhu-3-0.jpg
8/10/2016 10:09:46 PM • Toro Power Lawn... • Answered on Aug 10, 2016
Need the plug for the charging port. Can find the whole harness, but just need the plug
Hi try. This website. http:/www.toro.com
6/7/2016 12:42:29 PM • Toro Power Lawn... • Answered on Jun 07, 2016
Toro Model 20070 lawn mower starts and runs, just does not seam to have a lot pf power does anyone have a lack of power issue with their Toro 20070 Pace Lawn mower. Runs fine just no balls
could be dirt in the carby , blocked fuel filter or lack of adjustment in the accelerator cable I will go for a cable adjustment as they slip under the clamp on the carby bracket when the throttle is pull wide open
5/31/2016 12:05:56 AM • Toro Power Lawn... • Answered on May 31, 2016
When I hold the bar down that engages the blade it will not cut?
Is the blade sharp?
5/17/2016 9:47:49 PM • Toro Power Lawn... • Answered on May 17, 2016
Toro Power Lawn Mower Logo
488 questions posted
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
View Most Popular
Toro Garden
  • Toro Garden
Most Popular Question
6 5 hp toro lawn recycle mover will
  • Garden
