20 Most Recent
Ariens 48" Riding Lawn Mower Blade 00450200 Questions & Answers
Keeps shutting off. Do riding Lawn Mowers have
sort of they have a stator under flywheel that charges battery. if your carb has an electric solinoid on it it need voltage to stay open but that is supplied by battery. solinoid works by key switch.switch could be bad ,solinoid could be bad ,could have fuel feed problem or spark problem need more info how long does run? does it start right back up?ect hope this helps
Ariens Zoom 40 Zero-Turn Mower won't drive
https://lawnmodel.com/ariens-riding-mower-transmission-problems-fixes/#:~:text=A%20worn-out%20or%20broken%20drive%20belt%20will%20also,when%20the%20mower%20is%20running.%20Defective%20pressure%20switch
Mt ariens Ezra 1742 won't spark and start
Check the start relay (not starter solenoid) energizes during crank. If the start relay does not energize then the magneto kill shunt is closed, hence no spark.
Comment for further assistance.
Model 915017 1542 zero-turn mower. How can I remove a deck pulley spindle?
See parts diagram
https://www.ariens.com/en-us/partsdiagrams?aribrand=ARN#/Ariens/915017_(000101_-_)_EZR_1542%2c_15hp_B%26S%2c_42%22_Deck/42%22_Mower_Spindle/6415040015/07200057/y
Likely you will need to remove the deck from the mower.
Then remove the blade, tray, and retainer to expose the woodruff key. Remove key and spindle should slide out of the spindle housing.
