20 Most Recent Craftsman Home Repair Kit Glue Gun Bond Mend Seal Caulk Questions & Answers
I have a Sears Craftsman
3/29/2014 8:31:32 PM • Craftsman Home... • Answered on Mar 29, 2014
I want to attach a
i would let the glue set for at least a few hours before inserting the screw. use an industrial strength (contractors) glue stick
2/26/2013 12:57:08 PM • Craftsman Home... • Answered on Feb 26, 2013
Need a manual for craftsman e-z fix glue gun
http://www.manualslib.com/brand/craftsman/this page has lots of craftsman user's manuals
2/26/2013 12:38:17 PM • Craftsman Home... • Answered on Feb 26, 2013
Were can i find an owners manual for the e-z fix
you can find the manual on ebay or amazon. does the gun work?
2/26/2013 12:07:15 PM • Craftsman Home... • Answered on Feb 26, 2013
Need instruction manuel for E-Z fix repair kit
you can find it on ebay, but what is the problem and i can try to help you
2/26/2013 9:35:11 AM • Craftsman Home... • Answered on Feb 26, 2013
I used spray adhesive to
just use super glue or rubber cement, you don't even need a glue gun.
2/26/2013 9:26:44 AM • Craftsman Home... • Answered on Feb 26, 2013
I have a craftman e-z
go to the arts and crafts section in wal mart and bring the gun, you should be able to find a stick that will fit
2/26/2013 9:24:48 AM • Craftsman Home... • Answered on Feb 26, 2013
I have the same dilemna. Can't find replacement sticks--have you had any luck?
Have you tired on line search with google?
12/6/2011 11:00:01 PM • Craftsman Home... • Answered on Dec 06, 2011
Parts for 9-80444
Try returning the glue gun at the local sears store for an exchange for one which uses round glue sticks.
1/18/2016 4:37:43 PM • Craftsman Crafts... • Answered on Jan 18, 2016
I have a craftsman glue gun model 2010 were do i get glue sticks for it
Go to Sears or to the Craftsman web site to order more glue sticks.
1/2/2015 8:28:37 PM • Craftsman Crafts... • Answered on Jan 02, 2015
Sears craftsman e-z home rapair kit oval giue sticks formula400
Use Google Shopping to find it. If they don't make them any more, you may have to get a new glue gun.
4/20/2014 5:15:41 PM • Craftsman Crafts... • Answered on Apr 20, 2014
Can't get glue stick into gun
Plug it into wall outlet and let it become hot (without plugin any glue into ) about an hour..
When it gets hotter the molded glue in the back channel/barrel of the gun will be melted and back side will be freed to accept a new glue stick.
My regards
10/6/2010 8:07:26 PM • Craftsman Crafts... • Answered on Oct 06, 2010
I want to make a necklace for my sons wedding with pearls but they are so small and delicate I am not sure what thread will work with it?
Pearls often have very small holes. You need to use a natural silk thread or another very fine thread. It really depends if you plan to knot between pearls, if so that will affect your choice of thread, so make sure you get advice from a beading expert before you buy.
4/7/2024 2:22:50 AM • Crafts & Hobbies • Answered on Apr 07, 2024
Are there soap making kits that are good for kids?
Amazon have a good soap making kit for kids but if your kids are young you should make sure that you supervise the hot parts as it can be quite dangerous.
http://www.amazon.com/Cool-Kids-Soap-Kit/dp/B00124WCJ0
3/18/2024 9:18:03 AM • Crafts & Hobbies • Answered on Mar 18, 2024
2answers
My cricut explore air 2 will not load my mat, what could be the problem?
Cricut Explore Air 2 helps in cutting the beautifully intricate designs using the compatible cutting machines. However, in some situations, you can get the problem where you will not able to use the mat. In this situation, you first make sure you are following the right guide to load the mat, check if the mat is compatible with your Explore Air 2 machine, or your device is not facing any problem. To get rid of this issue, you have to reset all of your devices and set up the machine once again. Also, check if the mat is not damaged, refer to the Cricut crafting guide for using the mat, use the compatible mat, and more. You can also connect to the Cricut customer support team to get more info from professionals to resolve the issue. cricut explore air 2-ibihixnmadozsxrjeznrdibm-d-1.png
3/11/2024 12:35:42 PM • Crafts & Hobbies • Answered on Mar 11, 2024
Constraints about making a Jaws of Life model with cardboard, split pins, syringes and plastic tubing.
Question edited for clarity, otherwise this question makes no sense. I presume you mean a MODEL of the Jaws of Life. Large capacity syringe powering a small capacity syringe with give a significant pressure advantage. The only issue I can think of is the the friction of the secondary piston may be too sticky on the wall of the smaller syringe but if you fill the system with water, you will get true hydraulic results because air can be compressed but water can't ...
2/22/2024 5:52:45 PM • Crafts & Hobbies • Answered on Feb 22, 2024
tip
Crafting Clear and Effective Troubleshooting Guides: A Handy Guide for DIY...
Are you tired of scratching your head over malfunctioning gadgets or appliances? Fear not! With a well-crafted troubleshooting guide, you can conquer technical challenges like a pro. Here are some expert tips to help you write troubleshooting guides that shine:
  1. Know Your Audience: Understand who will be using your troubleshooting guide. Are they beginners, enthusiasts, or experts? Tailor your language and level of detail accordingly to ensure accessibility and effectiveness.
  2. Start with the Basics: Begin your guide with an overview of the problem and its potential causes. Break down complex issues into simple, easy-to-understand steps. Remember, clarity is key!
  3. Step-by-Step Solutions: Provide clear, concise instructions for each troubleshooting step. Use numbered lists or bullet points to outline the sequence of actions users should take. Include relevant images or diagrams to enhance understanding.
  4. Use Descriptive Language: Describe symptoms, error messages, and actions in detail. Avoid jargon or technical terms that might confuse readers. If necessary, define unfamiliar terms or provide a glossary for reference.
  5. Highlight Common Pitfalls: Anticipate common mistakes or misconceptions users might encounter. Address these pitfalls proactively to prevent frustration and ensure a smoother troubleshooting experience.
  6. Include Troubleshooting Tips: Offer troubleshooting tips or tricks to expedite problem-solving. Share insights or shortcuts that can help users navigate tricky situations with ease.
  7. Test and Revise: Put your troubleshooting guide to the test! Walk through the steps yourself to identify any ambiguities or gaps in instructions. Solicit feedback from users to refine and improve your guide over time.
  8. Update Regularly: Technology evolves rapidly, so it's essential to keep your troubleshooting guide up-to-date. Stay informed about new developments, software updates, or common issues reported by users. Update your guide accordingly to ensure its relevance and accuracy.
Remember, writing an effective troubleshooting guide is as much an art as it is a science. By following these tips and putting yourself in the shoes of your audience, you can create guides that empower users to tackle technical challenges with confidence. Happy troubleshooting!
on Feb 17, 2024 • Crafts & Hobbies
I need 4 springs for under blades for a pro tech cs6007 contrator series planer
you can find replacement blades (also known as knives) made from a special V2 alloy (high-speed steel) on the MyWoodcutters website. Each set includes 3 HSS blades specifically designed for the CS 6007 model. The cost for a set of 3 blades is $61.50 to replace the springs for the under blades, I recommend checking with a local hardware store or contacting ProTech directly to inquire about availability.. For other parts or accessories, consider exploring online marketplaces like eBay.
2/12/2024 3:32:30 AM • Crafts & Hobbies • Answered on Feb 12, 2024
Craftsman Home Repair Kit Glue Gun Bond Mend Seal Caulk Logo
Popular Tags
16 questions posted
Top Craftsman Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Craftsman Craft and Hobby Expert? Answer questions, earn points and help others
View Most Popular
  • Craftsman Crafts & Hobbies
Most Popular Question
craftman e z
  • Crafts & Hobbies
