20 Most Recent
Robin Subaru RGX7100 7100 Watt Gas Generator Questions & Answers
The generator kicked the breaker of and was
What type of load (electrical) was hooked up to this generation?? If the surge
voltage and current was exceeded above the generator maximum for any length of
time. There problems, it could be the regulator, insulation burnt off the
windings.
I am taking a guess here. Now, 7100 Watts is it typical surge wattage. This
mean that the generator will deliver 7100 Watt (voltage times current) this is
know as the power factor. The actual operating load would be 6800 Watts and I
would even operator the generator at its peak wattage. Something in the
neighborhood of 10--15% less the peak wattage. Therefore a good positive
theatrical Wattage would be 5800 to 6350 operating wattage. Then this generator
would run all day.
Just remember Ohm's Law. Current plays a big factor in loading of a generator
while the operation voltage is at 120 AC Volts. Example: electric motor; Now
electric motor when starting will pull three time its operation current.
Operating current for a 1/2 HP AC motor is 6 amperes but start this electric
motor will require 18 amperes. This is one reason why they starting capacitors
on smaller electric motors. Larger three phase electric motor can literal stop a
generator cold...in its tracks. It put such a large demand on the generator it
stops the engine powering the generator. I have seen crankshaft break because
the generator could handle the heavy current load.
Remember, any time you are running a small gas powered generator. All ways
figure what the load and surge current load will be before hooking up any
generator. Normally this is figured in VA (volt/amps). Wish you lock.
GB...stewbison
I have a homelite LR4300 with the 7.5 HP Subaru engine. The governor is not working. Whats the poblem?
Unclear when stated that there is a governor issue? I assume you have a Robin/Subaru 7.5 H.P. engine model EY280YD2510 with erratic behavior leading up to stalling out when a load is applied or the generator is at no load status after several minutes of run time?. Couple of things to check would be starting with the fuel system. Is there stale gas in the fuel tank? Have you verified fuel flow from tank? Is the fuel cutoff valve free of debris? Is the carb fuel bowel been removed and inspected for varnish? Is the air cleaner clean? Next, Ignition system. Have you inspected the flywheel for excessive rust? Have you reset the air gap on the ignition module? Does the on/off switch work (measured with a meter for continuity?) Any visual signs of damage with all wiring or the ignition module itself? I once thought I had an governor issue where the issue ended up being that the flywheel was corroded to the point that once the engine was fully warmed up the control module would contact the rust build up on the flywheel causing engine surges no matter what the load was on the generator, and at times would stall the engine. Clean flywheel off if necessary and reset the air gap on the ignition module. If that fails then inspect the governor spring (the top spring on the carb. linkage assembly) for excessive rust that will change the tension on the governor arm.Replace if in doubt! When doing all this inspecting ensure you have fresh fuel, oil, air filter, spark plug gapped correctly, and ignition module that has been tested as sound! These Robin engines are smooth running heavy duty engine that will perform for many years if taken care of. Good luck!
Generator turns on and runs
Hi and welcome to FixYa, I am Kelly,
Since I don't have a model number to work with I am going to assume this is a generator with brushes. (I need your model number!)
Having said that... TRY THIS:
1. Plug in an electric drill to the output power plug and turn on the output power switch with the generator running.
2. Squeese the drill trigger switch and rotate the drill chuck as fast as you can. This will flash the field of the generator and often output power starts right away. NOTE: When power starts it will try and twist the drill chuck out of your hand. Just let go of the trigger and the drill chuck.
If you have an inverter type power head the steps are different for flashing the field. The easiest way is to do a male to male power cord from utility supply power connection and turn on the output power switch to re-establish a field in the PMG of the rotor.
There are other steps but without a model number this is what I am sending off at the moment. Respond with a model number if the steps above do not work and I will help you.
Thanks for choosing FixYa,
Kelly
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do
Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/
Quoting from link above: "
Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error :
* Press the Back arrow on the keypad - this step is to refresh the UIU ( the device)
* Type # 75 # - this is to check the signal strength
If it does not go back to the normal display
*Type # 80 # - this is to refresh the meter
Then lastly you can repair the meter and the UIU by # 36 #
The above steps will work better if you are outside the house because the meters uses the radio frequency connection
The above error will occur in instances of bad weather conditions or if there is load shedding or power failure
If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again.
SOLVED: Pole meter conlog rf con meter keep on freezing ...
Jan. 10, 2017
Meter reading shows rF CON instead of units available - Fixya
Jun. 24, 2018
SOLVED: Good day my conlog ip54 elecricity meter showd ...
Oct. 6, 2018
SOLVED: Rf con error - Fixya
Jun. 20, 2020
More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ...
How Do I Load The Activation Token On My Conlog Prepaid ...
Mar. 17, 2020
I Need A Technician To Fix This... - Nairaland / General - Nigeria
Jul. 22, 2019
I Need Number Codes To Reset Memmcol Prepaid Meter ...
Jan. 11, 2019
More results from www.nairaland.com
