20 Most Recent Bosch WFVC5400UC Washer Questions & Answers
4answers
Bosch 500 series washer E:27 error code?
turn dial to off. hold down both delayed start and spin select buttons and turn dial to the left one click, to the cold position. keep holding button until you here a click. let go of buttons and turn dial to off. Every thing should go back to normal. Just fixed mine and all is good.
3/12/2023 2:26:37 AM • Bosch WFVC5400UC... • Answered on Mar 12, 2023
2answers
Error code on Bosch washer
Just fixed the E:27 error code. Just turn dial to off and hold down delayed start button and spin selector button and turn dial to the left one click (cold). It should then click and open. open the door and turn back to off. Everything should go back to normal. this is something that should have been in the manual.
12/2/2014 11:29:27 AM • Bosch WFVC5400UC... • Answered on Dec 02, 2014
Bosch front load washer code E13 comes on
Bosch E-13 error code is a drain timeout code. This means the pump has run a certian amount of time without fully draining itself.This could be anything from a clogged drainline in your home to a clogged drainline in the machine, your pump is clogged, pump is burned up, no power to the pumpetc. Most of the time its either something jammed in the pump, or its burned up (from something being jammed in it).If your model has a filter on the front of the machine, put down plenty of towels and slowly undo the filter. Water will come out. Check to see if its blocked or if the outlet hose is blocked. The same E13 code on the WFMC series Bosch washer`s refer to a drainage problem, as you may or may not already know. (or in Bosch terms pump time exceeded). Anyway, here`s the most likely way to remedy a E13 code.Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)2. Find a drill bit or small screwdriver that fits in the hole in the round door. 3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a red ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan ) There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out5. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.6. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.7. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.Hope this helps (remember to rating this answer and leave us a testimonial comment)..
10/17/2014 2:14:40 PM • Bosch WFVC5400UC... • Answered on Oct 17, 2014
manual
0answers
0answers
E:27 error code. Wet
E:27 message means that the door locking mechanism has malfunctioned and/or is overheating. Unplug the machine for 30 minutes and try again. If that doesn't solve the problem you need to call the service.
5/28/2011 8:56:39 PM • Bosch WFVC5400UC... • Answered on May 28, 2011
Bosch waher WAE24469GB .the start reload light
Could there be something in the drain pump lint tray/filter blocking it ? I know your machine is VERY young but you never know ;-0)
Just in case here are my general guidance notes to assist. It is worth while carrying a check out on a regular basis anyway, especially when us males tend to leave things in our pockets!
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
2/27/2011 1:10:00 PM • Bosch WFVC5400UC... • Answered on Feb 27, 2011
Does not high spin at
usualy if no high spin either outof balance or running to small of load
1/26/2011 5:42:37 AM • Bosch WFVC5400UC... • Answered on Jan 26, 2011
I have a Bosch washing machine WFVC5400UC and the
hello if total dead check the glass fuse inside the washers power supply if blown make sure you use the same rated fuse if blows again then you have a dead short somewhere hope it helps
regards
shaun
1/8/2011 9:30:30 PM • Bosch WFVC5400UC... • Answered on Jan 08, 2011
Bosch Vision washer door seal replacement
You will need the numerical model number.
Bosch - Door Boot Seal 00701333 - Appliance Parts
PartSelect.ca https://www.partselect.ca > PS8735900-Bosch-0070133... Nov 10, 2021 - Door Boot Seal ; This part fixes the following symptoms: Leaking ; This part works with the following products: Washer. ; This part works with the ... Rating: 5 · ‎ 1 review
00667487 Bosch Washer Door Boot Gasket
Reliable Parts https://www.reliableparts.ca > ... > Bosch Dishwasher Parts Door boot gasket works with some Bosch, Thermador, and Gaggenau models of washing machines. This is a genuine OEM part that works for some models of Bosch, ... $101.27 · ‎ In stock
Shop Bosch Washing Machine Gasket & Seal Parts
Repair Clinic https://www.repairclinic.com > Shop-For-Parts > Bosch-... Find Bosch Washing Machine Gasket & Seal Replacement Parts at RepairClinic.com. Repair for less! Fast, same day shipping. 365 day right part ..
4/15/2024 7:31:48 PM • Bosch Washing... • Answered 3 days ago
Bosch 100 Nexxt washer won't spin. Filter cleaned of debris, belt replaced. Drum can't be spun by hand, drags and seems misaligned after unbalanced load with noise coming from drum.
That sounds like the bearings have collapsed. Time to call a domestic appliance engineer or look for a new machine.
4/10/2024 6:18:33 AM • Bosch Washing... • Answered on Apr 10, 2024
Bosch lr30 receiver not turning on
Potential causes and fixes: Battery Terminal Corrosion: Cause: If your Bosch laser receiver has been submerged in water, the battery contacts and sometimes the circuit board may have corroded. Fix: Remove the batteries and clean the battery terminal contacts. Pry open the bottom cover and clean any corrosion on the circuit board. Calibration Issues (for Bosch GLL 2-20): Cause: Dropping the Bosch GLL 2-20 can lead to misalignment and errors. Fix: The best way to address this problem is to calibrate the laser level. You can either contact the Bosch service center or follow the calibration instructions in the manual. General steps for calibrating a laser level with a misaligned pendulum: Remove the screws and outer cover. Locate the pendulum hanging in its stationary position. Remove the glass window of the laser level. Adjust the stationary position of the hanging pendulum using the main adjustment screw. Fine-tune right-left adjustments using other smaller adjustment screws. Reassemble the laser level. Cracked Glass Lens (for Bosch GLL 2-50): Cause: If the horizontal glass lens is cracked, it affects accuracy and safety. Fix: Unfortunately, this problem is often unrepairable. It's advisable to replace the laser level to ensure safe operation1. Remember to lock your laser level when not in use or during transportation to prevent pendulum movement1. If these steps don't resolve the issue, consider reaching out to Bosch for professional assistance or repair
4/7/2024 11:28:06 AM • Bosch Washing... • Answered on Apr 07, 2024
Bosch WFVC5400UC Washer Logo
36 questions posted
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
error code bosch washer
  • Washing Machines
