20 Most Recent
Apple iPad (16 GB) WiFi Tablet PC Questions & Answers
How do I add my iPad as a device on my Amazon Account
Add a device to Amazon??? I have Amazon and have never heard of having to do this. The Amazon accounts authorize connection by username and password; it doesn't care what kind of device you are connecting to it by.
My IPad will not turn
First of all. Be sure to plug in the charge and if that dosn't work it might be broken.
My ipad is stucked.
This tutorial will explain how to force your iPad to restart if it gets stuck or freezes up.
Forcing your iPad to restart will not cause any loss of data - with the possible exception of any work you were doing at the time the iPad and/or App froze, forcing you to restart it.
Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom). Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
How do you connect the iPad to iTunes when it won't turn on?
You can try these:
1. Force Restart iPad:
Hold the Home button and Wake button at the same time for about 10 seconds. Your find your device vibrating and get out of the iPhone boot loop.
2. Try an iPhone system recovery software
If your iPad cannot be force restarted, TunesKit iOS System Recovery is a wildly accepted tool to make your iPad back to normal with almost every problem solved.
I keep getting Expected status code(200-209) got 503
Reasons of Avira Antivirus Error Code 503
• Your system gets shut down
• Corrupt os files
• Windows program crashing
• Inability to execute exe files
• Faulty installation
• Virus attack
• A glitch in the windows registry
Procedure to Fix Avira antivirus error 503
Procedure 1: Automatic Method
• Click Avira error 503 repair tool free download link
• Set it up on your PC
• Run Smart PC fixer software utility
• Scan your PC
• Click fix all to repair the Avira Error 503
Procedure 2: Manual Technique
Step 1
• Click Start button to view Start Menu
• After it, choose Control Panel option and click it
• Enter into system and security
• Click on Windows Update
• Get new update options by hitting the Check for updates button
Step 2
• Click on device manager
• Then click on Update driver
• Click Update driver software
Here are complete steps to fix
Avira antivirus error 503. Users, without technical knowledge, are advised not to fix this problem. They can dial 806-542-0999 Avira Support Number without any delay.
Cannot access face book
1. Delete the Facebook keyword in gfwinterinterceptor
2. Use VPN to access
Facebook.
3. Close the VPN and add the Facebook keyword in the gfwinterinterceptor
How to bypass setup without the previous owner's Apple ID
1. It is recommended to back up the content of the mobile phone before recovery, because this method needs to restore the system for
iphone, so the data on the original mobile phone will be lost. If you don't have it installed on your computer, please go to the Apple website to download and install it.
2. Wait for verification to collect data and collect all the information in the mobile phone database.
3. At this time, the software enters the collection state, and the software will automatically collect the information of the mobile phone. After the collection, the software will automatically pop up an information box.
4. After verification. We received an email.
5. At this time, the software enters the collection state, and the software will automatically collect the information of the mobile phone. After the collection, the software will automatically pop up an information box and click OK.
How do you delete photos from ipad?
To delete photos in 1st generation ipad tap photos,tap photos again then tap photo you would like to remove.When in full mode trash can is available.For 2nd generation and new ipad,tap photos then edit.Tap each photo to add check then tap delete to remove all checked at once.Please Rate
How do I print out of ipad 2
If you have a Mac you can do it this wayMake sure you have the Pages app installed on your iPad.Connect the iPad to your computer using the appropriate USB cable.Open iTunes, then locate your iPad in the source list and select the Apps tab. Scroll down to access the File Sharing Pane.The File Sharing Pane is a centralized location where you can manage the transfer of documents to and from your iPad. To print, transfer the desired document from the iPad to the Mac's hard drive. Then simply open and print using a device connected to that Mac or a device on the Mac's network.Alternatively, e-mail yourself any documents you want to print, then open them on a Mac with printer access and print from there. Printing using appsShop around. Each printing app works a little differently. When PCMag.com originally reported on iPad printing apps in April 2010, it found few that worked particularly well -- and several that didn't work at all. No doubt this trend has continued as developers continue to bring out new apps.PrintCentral is an app that can be used with iPad, iPhone and iTouch. Its developers tout it as a one-stop-shop for mobile printing needs. MacWorld has awarded it 4 out of 5 mice and EuroSmartz.com has named it its iPad App of the Week. It can print directly to most wireless printers.Whether you opt for PrintCentral or another printing app, make sure to review any instructions carefully to get the best performance.
How do i hard factory reset my apple iPad 16 GB model A1395
It's simple. You can complete this task with several steps. Just follow below steps.
You are able to reset iPhone to factory settings within your iPhone. You just need to go to "Settings > General > Reset" and then choose the categories you want to reset and then apply it. If you choose "Reset All Contents and Settings", then you will get all the files in your iPhone erased.
Once you tap on "Erase All Content and Settings", you will be asked to enter your Apple ID password. Next, you will see a Popup Message informing you that All media, data and settings will be erased from your iPhone. Click on Erase iPhone to factory reset iPhone 6 Plus.
For more methods, check:
How to Restore iPhone to Factory Settings
