20 Most Recent
Haier DE45EAL Dehumidifier Questions & Answers
How do I reset the humidity % on my DE45EAL. It
The easiest way to try to reset the dehumidifier is to turn it OFF & unplug it for 15 minutes. After the time has elapsed, plug it back in and turn it ON. The electronics should have reverted back to the original factory settings during that time out. In which case you can set the controls as you like.
Hope this helped you & thanks for choosing FixYa..
When I plugged in our
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air
temperature at floor level is colder than at shoulder level
in basement applications . Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If
none of the above solves the problem, it may be a case of the
compressor needs to be recharged with refrigerant gas or that the humidity condenser has failed. These things usually occur in units that are
5 years old or older. It's rare in a unit younger than that. But, it
can happen.
Hope this helps you to troubleshoot and solve the problem.
My DE45EA-L lights turn on
Jeff, if you mean the unit shuts OFF, but the control panel lights remain ON?
There are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
where the air
problem.
If
compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are
can happen.
Hope this helped you.
Unit will not run.
All I found it E 2 is the issue with sensor.
You can shutdown unit for an hour, turn it back on to see if the code is gone
if not. I
If not, try to troubleshooting sensor using the link below
http://www.dehumidifier1.110mb.com/troubleshoot-dehumidifier-sensor.html
If still not working, you might need to replace it. How old is yours?
You can find part by searching for it online
Good luck and let me know if I can further help.
Thanks
Why does my unit display
If you're referring to the small light, just above the fan blade icon on the control panel ... that's the fan speed. It reverts back to LOW each time the unit is manually turned OFF. I that's the one you were referring to, it's nothing to worry about. If you want to raise the fan speed to HIGH, press the fan icon.
Hope this helped to answer your question, Christina. Please let me know.
Lifted up the dehumidifier onto
It does have a tilt over safety feature. But if it wasn't plugged in when it tilted, it shouldn't have tripped the switch. However, if it was plugged in, it probably tripped the switch. Check your Owners Manual for how to reset the switch.
