20 Most Recent Directv RC-64 Remote Control Questions & Answers
2answers
Direct TV remote "tv input" button won't work with my Sony TV
I came across this looking for a similar solution for my Samsung TV, and I found the solution on ehow.com. Apparently after you program the remote for your TV you have to hold mute and select again until it flashes twice then put in 960 to make the remote control TV input too. Note you're remote should be in TV mode while you do this. It seems silly that the DirectTV guy wouldn't do this when programming the remote.
7/10/2021 1:33:08 AM • Directv RC-64... • Answered on Jul 10, 2021
Sceptre tv input won't work with driect tv remote
I have a spectre TV and can not get it to work with my satellite or remote
6/19/2017 10:47:39 PM • Directv RC-64... • Answered on Jun 19, 2017
I dont have a remote for a apex converter box DT250A AND NO CODE FOR IT I WANT TO USE MY INSIGHT REMOTE IT A C14402 NEED HELP THANKS
If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the sites by "MOSAIC" view, will make surf easier. http://electrohelponline.blogspot.com/
2/3/2014 2:18:24 PM • Directv RC-64... • Answered on Feb 03, 2014
0answers
42 LW5700
Be the first to answer 12/19/2013 3:35:00 PM • Directv RC-64... • Posted on Dec 19, 2013Be the first to answer
Digital stream codes
0021,0026,9923. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
10/27/2013 4:29:21 AM • Directv RC-64... • Answered on Oct 27, 2013
Whats the code for digital stream conv
8220
10/26/2013 10:46:38 PM • Directv RC-64... • Answered on Oct 26, 2013
Dish tv remotes
What do you want? User manual to this remote control? If so, click here to download it.
10/19/2012 2:32:51 PM • Directv RC-64... • Answered on Oct 19, 2012
I need codes for my etec tv for a directv remote
This TV brand is not listed with direct tv remote control. Do a code search method. If there is a pre-programmed code in the remote, you can setup your TV by this method. For more details, visit the site 'Electro-help'. All details about code search method is described here in detail. Type in "electronicshelponline.blogspot" into your browsers' search box and click search. Pull up older posts there.
6/25/2012 2:56:48 AM • Directv RC-64... • Answered on Jun 25, 2012
Can't set up Direct TV
- Set the "Mode Switch" to TV.
- Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
- Enter the code: 10178.
9/7/2011 11:22:19 PM • Directv RC-64... • Answered on Sep 07, 2011
I was programming the new remote to a new TV
Hello
What is the model number of your Insigina TV?
7/3/2011 3:31:08 AM • Directv RC-64... • Answered on Jul 03, 2011
I need the code for the apex dt 250a for my direct
Use 00749 if you have a directv remote and you're trying to program it to the Apex DT-250 digital converter. I just did it and it works. If you have any other universal remote, it may require a three or four digit code; in those cases, use 749 or 0749 respectively. I tried them and they work with the Apex DT-250...There is one big problem though... How do you do an auto channel search with the directv remote? Or any other universal remote? If anyone has this answer, please let me know.
6/7/2011 7:04:21 AM • Directv RC-64... • Answered on Jun 07, 2011
I need the code for
Try 10748 for your apex digital unit. If this doesn't work, you will have to go through the SetNStep procedure below.
StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Let me know if this works. Thanks.
3/5/2011 12:26:55 AM • Directv RC-64... • Answered on Mar 05, 2011
Directv RC-64 Remote Control Logo
Popular Tags
41 questions posted
Top Directv Televison & Video Experts
Alexander
Ngoro
john h
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Directv Televison & Video
Most Popular Question
direct tv remote tv input button work
  • Televison & Video
