20 Most Recent Texas Instruments TI-86 Calculator Questions & Answers
2answers
How do I reset my TI-86 after a long period of no use.
Every time you change batteries this will happen to you. First press 2nd then press and hold the down arrow. Hold until their is no black in the background but you can still see the numbers on the screen.
3/11/2024 2:42:08 AM • Texas... • Answered on Mar 11, 2024
2answers
How do you make a residual plot? And I don't mean
The simplest way would be to create a table where each x-value has a y-value that is the residual at the corresponding x. With a 2-list data set you can plot you residual plot.
9/12/2022 8:02:33 AM • Texas... • Answered on Sep 12, 2022
2answers
Error 07
Error 07 is Syntax Error. From the manual: "You entered a value; look for misplaced functions, arguments, parentheses, or commas; check the syntax description in the A to Z reference."
If you can't find and fix the error, could you post the expression producing the error?
12/7/2020 11:38:55 AM • Texas... • Answered on Dec 07, 2020
My TI-86 screen had white
There is no solution for old age. Get a newer calculator.
5/28/2018 3:05:29 AM • Texas... • Answered on May 28, 2018
5answers
HOW TO FIND CUBE ROOT
There is a way to do it. I believe you go into "complex" or "math" buttons. These buttons are yellow on the calculator. Therefore, to access them you must hit "2nd" then the button.
Better yet, you can also get around this dilemma another way. You can enter "the cubed root of x" by raising x to 1/3.
For example the cubed root of x = x^(1/3). It is best to place parentheses around 1/3 so the calculator knows exactly what you mean.
Another example, the "cubed root of (x + 1)" can be entered by:
(x+1)^(1/3) Note the parenteses around both (x+1) and (1/3). This applies if the radical cover both "x" and "1".
Hope this helps.
2/7/2018 8:32:26 AM • Texas... • Answered on Feb 07, 2018
I have a TI-86, whenever i input - it shows Ans- and then it show that is an error. how can i fix it.
The - key is for subtraction, an operation that needs two numbers. If you press - as the first key on a line, the calculator assumes you want to subtract something from the previous answer, Ans. If you want to enter a negative number, use the (-) key on the bottom row of the keyboard, just to the left of the Enter key.
8/18/2016 12:22:50 AM • Texas... • Answered on Aug 18, 2016
2answers
Graphing x=f(y)
See images below graphing-x-f-y-msd4ywcziatgb1emjkfxnjsa-1-0.jpg graphing-x-f-y-msd4ywcziatgb1emjkfxnjsa-1-1.jpg
5/3/2016 6:00:30 PM • Texas... • Answered on May 03, 2016
How do I find the cube root button on my TI- 86
There is a relation between roots and fractionary powers.
2nd root (square root) of X = X^(1/2) power 1/2
3rd root (cubic root) of X = X^(1/3) power 1/3
4th root of X = X^(1/4)
n-th root of X = X^(1/n)
Use the raise to arbitrary power key labeled as a caret [^] or [X to the y] or [Y to the x]
Hope it helps.
12/13/2015 2:04:31 AM • Texas... • Answered on Dec 13, 2015
I'm trying to graph and get error 07
See cap image below trying-graph-get-error-07-x532urwfeg1wrndju4ovone4-4-0.jpg
5/27/2015 8:39:29 PM • Texas... • Answered on May 27, 2015
Reduce the fraction 83/360
83/360 is already reduced to lowest terms since 83 and 360 have no factors in common (other than 1).
11/7/2014 5:36:22 PM • Texas... • Answered on Nov 07, 2014
How do I convert fractions to decimals on a TI-86 calculator?
Just divide the numerator by the denominator. For example, to convert 1/4 to decimal, press 1 / 4 ENTER and see .25
9/15/2014 9:30:15 PM • Texas... • Answered on Sep 15, 2014
I am unable to graph a simple equation (y=-1.5x+3) on my TI-86 without getting error 07 message. How do I fix it?
Read on how to set up calculator for graphing. And check your input.
9/2/2014 3:24:09 AM • Texas... • Answered on Sep 02, 2014
Where is the insert variable key on my graphing calculator
You can type in an x-variable by pressing the x-var key. For other graph types, the variables r, theta, t, can be enter by pressing the appropriate function key. from the graph equation entry screen. f51d5be3-7d20-4e8d-96a7-7d1f031c4726.png
8/28/2014 11:21:20 PM • Texas... • Answered on Aug 28, 2014
When I try to enter a simple equation and graph it, I get error 07 message instead of graph.
Error 07 Syntax Means you made a typing error while entering the equation. Using the minus sign instead of the negation sign (change sign) (-), can produce a syntax error. Maybe you need to explicitly type the multiplication sign y= (-) 1.5*x +3 Try entering it as 3 - 1.5*x c3b67db6-adc8-4b0c-8e71-dc94a9bdbeb0.png eb28a330-c2e9-4879-857f-1e41bfe8515a.png
8/28/2014 10:48:31 PM • Texas... • Answered on Aug 28, 2014
How do I graph a simple equation, without getting an error 07 message? y=-1.5x+3
8/28/2014 10:40:49 PM • Texas... • Answered on Aug 28, 2014
How do I graph a simple equation on my TI-86, without getting an error 07 message? y=-1.5x+3
8/28/2014 10:40:18 PM • Texas... • Answered on Aug 28, 2014
17/4 as a percent
425%
6/20/2014 5:09:20 PM • Texas... • Answered on Jun 20, 2014
I need to estimate car
Hello Sir/Ma
Have you been seeking for a loan??
Have you had problems with your bank and they have refused giving you a loan?? Do you have bad credits?? Consider all these no problem .An organisation with Approved Lending Institution Status under Section 156 of the Housing Act 1985 as amended by the Housing and Regeneration act 2008.For more enquiries.
E-Mail address:[email protected]
6/12/2014 3:06:49 PM • Texas... • Answered on Jun 12, 2014
What is the reduced fraction form of 180%
1 4/5 or 9/5
6/12/2014 3:05:23 PM • Texas... • Answered on Jun 12, 2014
Texas Instruments TI-86 Calculator Logo
326 questions posted
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Texas Instruments Office Equipment & Supplies
Most Popular Question
find cube root
  • Office Equipment & Supplies
