20 Most Recent Yamaha Yamalube Outboard Oil Change Kit F200-F250 10W-30 Oil - check description Questions & Answers
How many cylinders in a f25 four stroke yamaha
Your motor has 2 cylinders.
5/26/2019 10:20:29 AM • Yamaha Yamalube... • Answered on May 26, 2019
Have a 2015 Yamaha 115 outboard 4 stroke after going full throttle and backing down alarm sounds. Need help
limited info generic answer check fluid levels ---filters --and pumps
4/12/2022 12:14:01 PM • Yamaha Boating • Answered on Apr 12, 2022
Where is the carburetor on my 1995 Yamaha waverunner 700
Nothing personal... but if you can't find the carburetors you DO NOT need to work on this unit!!!
11/12/2021 5:27:43 PM • Yamaha Boating • Answered on Nov 12, 2021
2000 50hp 2 stroke outboard. Why doesn't it start?
The carburetors are in desperate need of some PROFESSIONAL attention. They all stop up after sitting for that long.
11/12/2021 4:42:53 PM • Yamaha Boating • Answered on Nov 12, 2021
My 2015 Yamaha 150 4 stroke outboard will turn in on direction only. The wheel will turn the other way but not the engine
Many possibilities. Depends on your steering system: cable or hydraulic. Could be low hydraulic fluid or broken cable, damaged gear in steering column and more. If you not familiar with that systems then take it to your mechanic.
11/30/2019 2:16:32 PM • Yamaha Boating • Answered on Nov 30, 2019
Need to find out the year model of my Yamaha 15hp 684k 15fmh s1068042h so I can get an impeller kit.
Look for a plate on the shaft. If not call west marine
10/25/2019 1:48:50 PM • Yamaha Boating • Answered on Oct 25, 2019
I have a 2005 40 Yamaha 2 stroke that's not pumping water. Changed the water pump and have taken thermostat out and it's still barely pumping.
Must be some obstruction in there. Probably just before the water pump of just after.
10/17/2019 5:20:52 PM • Yamaha Boating • Answered on Oct 17, 2019
How much is a vintage low miles yamaha ex 650 worth
Two things depreciate faster than a car and they are boats and rvs. A vintage yamaha is a nice term for older yamaha. I will be worth what someone wants to pay for it. That said, if parts are still available and it runs well, no work needed, you may get $1000 to $2000 for it. But that depends on the area you are in and what other used ones are going for. All you can do is offer to sell it for some amount of money and see if anyone calls. Lower the price if no takers.
10/12/2019 2:55:47 PM • Yamaha Boating • Answered on Oct 12, 2019
Need to know about a clicking noise motor won't turn over 97 Yamaha 75 horse boat motor
Most likely, (1) it's an old worn out battery, low charge, poor or corroded cable connections. Inspect and clean them. You may want to jumper battery with your car battery. If problem persists, (2) check starter solenoid connections and output connections. (3) As a last culprit, it could be a bad starter. And make sure your engine is not frozen. (Take spark plugs out and turn the flywheel by hand).
9/29/2019 8:31:27 PM • Yamaha Boating • Answered on Sep 29, 2019
What HP is YAMAHA P 65 outboard engine
I believe the P65 is a small engine with 3.5 hp.
9/19/2019 4:54:47 AM • Yamaha Boating • Answered on Sep 19, 2019
Derrick Schultz is a FIXYA expert this week - Biggest spammer in competition with others. I have a 2004 Yamaha Jet ski that wont start, it clicks but wont start' the battery is good
I got this free Pdf manual from reliable-store. com for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 years
8/21/2019 3:22:07 PM • Yamaha Boating • Answered on Aug 21, 2019
F you get water inside head of Yamaha xlt 1200 engine what shoud i do
8/20/2019 4:47:17 AM • Yamaha Boating • Answered on Aug 20, 2019
1998 yamaha waverunner xl1200 setting for a year checking compression # 1 62 psi # 2 80 psi # 3 90 psi is that ok
Not a problem if 1 drops below 60 issues will start. Put 5 oz of marvel mystery oil in the cylinder to help free up the rings. Pour in turn over engine do not start. Let sit over night.
8/20/2019 12:43:17 AM • Yamaha Boating • Answered on Aug 20, 2019
Yamaha Yamalube Outboard Oil Change Kit F200-F250 10W-30 Oil - check description Logo
3 questions posted
Top Yamaha Boating Experts
neil
Stan Ford
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
View Most Popular
Yamaha Boating
  • Yamaha Boating
Most Popular Question
many cylinders in f25 four stroke yamaha
  • Boating
