20 Most Recent
Westinghouse Electric LCM-17v2 17" Monitor Questions & Answers
I need a power cord
Look at the power socket. It should be the same as the one on the back of the computer.
You should be able to find one in just about ant electrical, electronics or computer store.
When i turn on my westinghouse 17
Hi
Well that's the age old question. Is it worth repair? The problem is probably 6 capacitors in the power supply that have aged significantly. In my shop those caps would run approx $2.00 each with a total labor charge of $50.00. Now whats the charge where you live? Then you can decide if it's worth a $62.00 repair or a new monitor for $150.00. Good luck
I have a LCM-17v8 17in Monitor and it seems to be
The internal power supply in the monitor is about to die. This is a very common problem with LCD monitors after 2-3 years of use. Check out the pages on monitor repair at our site:
www.ccl-la.com We have the parts you need to do the repair and we will have a repair guide posted for your monitor by tomorrow night 01/06/2010. If you can solder then you should be able to do the repair yourself, it involves changing about 5 parts and a little soldering. If you don't want to do the repair, we do offer repair services. You can get more details at our web site.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
