20 Most Recent
AEG T58840 Dryer Electric Questions & Answers
Tumble dryer keeps stopping and showing E50
E51 - Motor power triac short-circuited.
E52 - Intervention of motor overheating safety cut-out.
E53 - Motor triac "sensing" circuit faulty.
E54 - Motor inoperational.
Dado
E60 aeg 37840
E61 - Insufficient heating (maximum time exceeded)
E62 - Power relay to heater unit faulty
E63 - Intervention of auto-reset thermostat on the heater unit.
Dado
Error E60 dryer
E64 - Heater thermostat.
E65 - Fan motor triac faulty.
E66 - Fan motor thermal protection.
E67 - Triac control faulty.
Dado
Tumble dryer isblowing cold air only?
Your dryer is called smart dryer and in this case should have to generate familiy code E60 (or any of exactly fault code E61,62,63,64,65,66,67) if blowing cold air, as you explain. Means something is wrong with heating phase (drying).
So, in this case could be: Heater unit faulty; Wiring faulty; NTC sensor faulty/out of position; Electronic board faulty;
Thermostat faulty; and finally fun motor - but considering that it blows cool air I guess that is correct.
Dado
No heat
There are many things that could be wrong. On most machines there is an electrical diagram somewhere inside or on the back of the cabinet. You can check each item in the heater circuit until you find the faulty item. On most dryers it is the "over heat" fuse link that goes first, but there are MANY other possibilities. First thing.... make certain all switches are in the correct position, not half pressed in or 2 pressed at once. I hope this is helpful.
Our tumble dryer is not
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis
electric no heat tip...
heatman101
