20 Most Recent Sanyo New Original RCS4HVPIS4U Remote Control Questions & Answers
0answers
Sanyo TV power cord removal Model DP19649
It unplugs.https://www.amazon.com/POWER-CABLE-SANYO-DP19241-DP26670/dp/B019XGHRO8orhttps://directtvparts.com/sanyo-tv-dp19649-power-supply-1av4u20c38500-dac-12m069-2995321500/
4/3/2024 6:15:09 AM • Sanyo Televison... • Answered on Apr 03, 2024
Sanyo 55" inch Television. Where can I buy a replacement stand for it please?
Question edited for clarity. I doubt it is 55' feet, so I made it 55" inch. :>D No model given, 'Sanyo 55" is just one model in a range ver 20 years. You could go the universal route? https://www.google.com/search?q=Sanyo+55%22+inch+Television+replacement+stand or Google Sanyo (model) replacement stand ..
11/19/2023 3:52:11 AM • Sanyo Televison... • Answered on Nov 19, 2023
2answers
What is the regulator of sanyo crt tv model st-21g1
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ http://schematicscom.blogspot.com/ http://electrotechnician.blogspot.com/ Circuit diagrams of many popular brand TVs and other devices are given.
10/19/2023 3:02:11 AM • Sanyo Televison... • Answered on Oct 19, 2023
Sanyo FW40D36F television Smart capable?
Question edited for clarity and toss in dome CAPS. It is a nice set, but No, it isn't a Smart TV. https://www.sanyo-av.com/ca/product/product.php?id=570 No Internet Connectivity which would make it one. Versatile Connectivity With the multiple input/output ports, you have abundant options for connecting Blu-ray/ DVD Player, Video game console, Cable, and Satellite box, and Soundbar. ..
9/27/2023 5:23:58 PM • Sanyo Televison... • Answered on Sep 27, 2023
My tv brightness seems to adjust by itself
Try turning the Dynamic Contrast feature off. https://www.manualslib.com/manual/2679000/Sanyo-Fw32d08f.html?page=21#manual ..
8/31/2023 5:48:00 PM • Sanyo Televison... • Answered on Aug 31, 2023
Cannot scan for channels on remote
The remote model number doesn't help directly. This remote controls several Sanyo TVs including the DP46142 and DP32242. Manuals Lib has the owner's manual (copyright 2012) here: https://www.manualslib.com/products/Sanyo-Dp46142-77711.html . Press Menu (below and to the left of the arrow keys). Select Setup (the icon that looks like a satellite dish) using the left/right arrows. Press the down arrow and go to ANT/Cable setup. Press OK (in the center of the arrow keys). Use the left/right arrow keys to make sure that the Ant In line is set to Antenna. Press OK. Go down to Auto Setup and press OK. Choose from All Channels, Analog Channels and Digital Channels and press OK again. Select Apply and press OK when the scan is finished. (All channels and Digital Channels will work the same way since most analog channels are no longer broadcasting.) See https://www.manualslib.com/manual/306779/Sanyo-Dp32242.html?page=22#manual . Note: digital channels will not display if the signal strength is low. You may need a different antenna or a different antenna placement. See antennaweb.org or tvfool.com for suggested station transmitters. I hope this helps. Cindy Wells (note: the physical buttons on the TV should work to navigate the menu. Use the channel buttons for Up/Down and volume for left right. The OK button is the Input button.)
7/1/2023 8:25:21 PM • Sanyo Televison... • Answered on Jul 01, 2023
Sanyo amp stuck in standby mode can I pull it out this mode
When in the standby mode the 3 or 5 volt standby voltage is present for the main cpu IC to "wake up" the power supply, and put it to work, this is a signal that is introduced to the power supply when the on button is pressed, or a command from the remote, also if some components are defective and drawing to much current it won't come out of standby as well, this will require some electrical engineering skills to troubleshoot the amp, I suggest you take it somewhere to have it serviced unless you have the knowledge and test gear to fix it yourself.
3/29/2023 9:25:08 PM • Sanyo Televison... • Answered on Mar 29, 2023
Sanyo DP22640 television that has shrunk on both sides?
If you have already tried replacing the mainboard and it did not fix the issue, then the problem may not be related to the board. Here are a few other potential causes for a TV screen to shrink on both sides:
  1. Picture settings: Check your TV's picture settings to ensure that the aspect ratio is set correctly. If the aspect ratio is set to "zoom" or "wide," it can cause the picture to appear smaller on both sides.
  2. Overscan: Some TVs have a feature called "overscan" that can cause the edges of the picture to be cut off. Check your TV's settings to see if there is an overscan option, and if so, turn it off.
  3. Defective panel: If neither of the above solutions works, it's possible that the issue is with the TV's panel itself. In this case, you may need to have the TV professionally serviced or replaced.
It's also worth noting that shrinking on both sides can sometimes be a normal behavior for certain types of content, such as older movies or TV shows that were originally shot in a different aspect ratio. In this case, the content may simply be displaying as intended.
3/15/2023 4:46:46 AM • Sanyo Televison... • Answered on Mar 15, 2023
2answers
No power on Sanyo DP50E44 TV
There is a main fuse inside the TV on the main power board you can check. However, usually when a fuse blows, it means there is something shorted. If it just blew from a surge, you may get lucky by replacing it with the exact the same rated fuse.
3/12/2023 7:41:32 PM • Sanyo Televison... • Answered on Mar 12, 2023
How do I reset my sanyo TV model DS 1 5230
Unplug it for a few minutes, verify all of your TV and antenna connections and try again. Verify your TV settings are set for antenna instead of cable. If you get no signal again then you may have an issue with the input connection, inspect for damage.
2/11/2023 5:06:14 AM • Sanyo Televison... • Answered on Feb 11, 2023
My Sanyo tv dp42841 screen is upside down and mirrored I tried resetting and not fixed how do I get it back to normal with universal remote
You will need to click on the menu button on your TVs remote and then select the factory menu and next click on the factory settings to have the screen be not upside down anymore.
1/29/2023 7:34:13 AM • Sanyo Televison... • Answered on Jan 29, 2023
Sanyo New Original RCS4HVPIS4U Remote Control Logo
1 questions posted
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
cannot scan channels remote
  • Televison & Video
