20 Most Recent
Swisher 44-Inch 12.5 HP Trailcutter #RTB12544 Questions & Answers
Where to buy bearings
There should be a number on the bearing itself. Take that to your local auto parts and they can cross it over to any number of manufactures.
Change belt
Changing the belt on the swisher 44' rough cut - mine is a model RTB134412v. You have to remove the belt guard (4 bolts) and then the 6 bolts holding the engine on to the deck. Lift (or tilt) the engine up and loop the 1/2"x50" belt (I got a husky replacement belt at tractor supply) through the wire belt guides and around the engine belt drive. Then loop the belt around the larger blade drive. It takes about 30 mins or so. Hope that helps.
44 swisher
THAY SHOULD MOOVE THE ONE THAT WONT MOVE NEEDS BEARINGS
Just purchased the RTB12544-CA. There are no
I wish I had an answer. I just bought a Swisher Trail Cutter this weekend (3-27) and have the exact same question. Where does the console assembly mount? On the mower deck? The blades have to be "engaged" in order to operate. I do not have an electric start....it is a pull start....like a simple lawn mower.
