20 Most Recent
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Questions & Answers
How do I fully bleed
Locate the bleed cap along the hydraulic lines. And open it slightly
Then open the fluid reservoir and Pump the fluid through, Close bleed nipple and then apply lid to reservoir and then bleed is complete.
Wheel horse transmission problem
moved you from cars to DEERE
when did it last run right , never, last year, last decade or found it dead in a barn , History matters.
there is no tractor forums here, just mowers etc.
is this belt drive or hydastatic drive like see on Cub-Cadet's
Garden tractor it is, not real tractor.(farm)
yes it is hydrostatic
so is this the gear box full of fresh lube oil? spec oil clean.
next is the drive from engine to drive (pulley) spinning?
belt not missing or slipping or shreaded or loose?
make sure controls to hydra box work end to end.
and check pump pressure by the book,"?
the pump is that finned thing on the side. below.
buy the shop manual and it covers trouble shooting.
What causes the error code on my John Deere 668b SPN 94 FMI 3 fuel rail pressure voltage out of range high?
"Out of range high" or "Voltage above normal, shorted to high source" implies the fuel rail pressure sensor signal wire is shorted to the sensor 5V or other voltage source or the sensor itself has failed.
Likely there is a short in the harness from abrasion or rodent damage but not the only cause. You don't want to start pulling on the harness and inadvertently open the short or the problem will likely reoccur at a most inopportune time.
You'll want to carefully disconnect the sensor and the opposite end of the harness and perform a continuity test between sensor 5V and the sensor signal wire. If no continuity, the harness is not shorted. Then you'll need to do further testing to determine if the problem is the sensor or the ECU.
John Deere 2250 Tractor, nothing works!
Check battery voltage.
It's an older mechanical injector diesel and fuel control so once running it needs no electrical power. The dash lights etc. are easily powered by the alternator. But once you shut if off, a bad battery cell or poor battery connection may effective kill the electrical system.
I have a John Deere
It is the pump and the pumps are about 1000 dollars. They are not that hard to install. IT should cost about 1500 total.
