20 Most Recent Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Questions & Answers
2answers
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.1a7d956e-b15f-492f-a2e9-3b5139364744.jpg
9/12/2021 5:09:56 AM • Bosch 24 in.... • Answered on Sep 12, 2021
5answers
Bosch Door Handle: Loose
I had the same problem with my Bosch dishwasher.I came to this web site to find out how to get the door off.I took the experts advice,placed 4 pillows on the floor in fromt,opened the door,took out the screws and the front panel dropped down.It was so easy,the plastic spacers stayed in place.I put a little J B weld on the handle screws and tighted the handle and put everything back together,12 minutes tops.Thanks for the help,thankful in Georgia
6/25/2021 11:47:39 PM • Bosch 24 in.... • Answered on Jun 25, 2021
3answers
Can't close the door and finish the wash..
I'm not familiar with your model but I have a SHY66C and did the same thing. I had to open the door and remove the screws around the perimeter and take off the door skin. I then removed the screws holding the top plastic cover and took it off. You can then pry out on the metal tabs holding the hard plastic door latch and pull down on it to remove. There is a spring loaded leg on the outside that will be pointing toward you if it were in the installed postion and you are facing the door. Push in hard on the middle part of this leg until it clicks and resets the latch. Of course then just reinstall the door in reverse order. Remember that you have to put the plastic cover back on the top before putting the door skin back on.
1/31/2019 6:17:53 AM • Bosch 24 in.... • Answered on Jan 31, 2019
Bosch SHX45M05UC/48
Under the dishwasher you should she a hose barb by the drain pump assembly. One end of the drain hose hooks to the pump and the other to your drainage system.
1/13/2018 6:49:00 PM • Bosch 24 in.... • Answered on Jan 13, 2018
Bosch dishwasher leaving food stains
You may be experiencing this problem due to the soap you use or too much soap. Run a cycle without soap but put a cup of white vinegar in the machine. Then just use Cascade dishwashing packets. If your filters are clean and the pump is working that should take care of your problem. Do NOT use the inexpensive soaps on the market and especially don't use more than what is recommended. This leaves a film on your dishes and will cause it not to clean or rinse well. (I don't have any connection to Cascade - I just know it works very well. Costco brand packets also work well.)
5/20/2017 3:30:07 PM • Bosch 24 in.... • Answered on May 20, 2017
2answers
I have a Bosch SHU66C02. I opened the door to
Contact the free support service of this company. www.repairclinic.com
5/3/2017 6:42:59 AM • Bosch 24 in.... • Answered on May 03, 2017
4answers
Put dish detergent in rinse agent dispenser by accident
Hello and welcome to Fixya.
Aside from physically removing the dispenser assembly ( which would be quite involved and include taking the door panel off ) you should be able to "nuetralize" the dish"soap" by adding as much "white vinegar" as possible into the same location as the soap...the jet dry reservoir.
In fact you may have to try this several times, but you could also try pouring straight water into the reservoir, but that will take some time since it is "soap" as opposed to detergent, hence needing a lot of water to de-lute it to much of a degree.
I'd go with the "white vinegar" and repeat that several times through a "rinse & hold" cycle. ( do not add any dishes or cutlery...run it empty )
You can also add a couple of tablespoons of "vegatable oil" directly into the bottom of the dishwasher and some of your regular "detergent" before starting the "rinse & hold" cycle. This will give the soap something to react with and the "detergent" will also help "neutralize" the soap,,,hopefully breaking it down as a result.
To answer the second part of your post...
The effect is going to be oversudsing in the rinse cycle since this is when the jet dry/rinse agent is dispensed in the cycle. So what I'm hoping to accomplish with these suggestion's is to minimize the oversudsing or prevent it all together until the reservoir is "purged" of soap.
Let me know how you make out. It usually works in the cases I've had...eventually. I've seen plenty as you are not the first nor will you be the last...we all screw up, that's life ;o)
Good luck.
macmarkus :)
4/20/2017 4:28:31 PM • Bosch 24 in.... • Answered on Apr 20, 2017
Bosch Dishwasher model SHU66C06 doesn't enter wash cycle
this sounds like flow sensor failure,it it fails machine will either not fill up or fill and drain without washing its a cheap part to replace and is fitted downstream of inlet valve behind l/h/s side panel either attached to inle hose or heat exchanger.
3/5/2017 9:28:58 AM • Bosch 24 in.... • Answered on Mar 05, 2017
I have a Bosch Exxcel
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
1/11/2017 4:37:06 PM • Bosch 24 in.... • Answered on Jan 11, 2017
Door lock
Pull the door latch towards the front of the dishwasher until it clicks in the open position.
4/23/2016 9:45:57 AM • Bosch 24 in.... • Answered on Apr 23, 2016
4answers
Squealing noise
The pump motor is beginning to seize up. You may be able to take the dishwasher apart and lubricate the bearings and keep it going for a while, but at some point you will likely have to replace the pump motor assembly.
1/20/2015 6:12:42 PM • Bosch 24 in.... • Answered on Jan 20, 2015
3answers
Bosch dishwasher: won't fill with water
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
9/19/2014 8:07:32 PM • Bosch 24 in.... • Answered on Sep 19, 2014
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
329 questions posted
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Bosch Dishwashers
  • Bosch Dishwashers
Most Popular Question
door lock
  • Dishwashers
