20 Most Recent
Brookstone Stunt Copter RC Helicopter Questions & Answers
Lack of power after charge
If your Brookstone Stunt Copter RC helicopter is not getting enough power after being charged, there could be a few different issues that could be causing this. Here are a few things you can try:
Make sure the battery is fully charged: It's possible that the battery was not charged for a long enough period of time, so make sure the battery is fully charged before trying to fly the helicopter again.
Check the battery connections: Make sure the battery is properly connected to the helicopter and that the connections are clean and free of corrosion.
Try a different battery: If the issue persists, try using a different battery to see if that resolves the problem.
Check the transmitter: Make sure the transmitter is properly charged and functioning.
Check the helicopter's Motor: Check the helicopter's motor to ensure it is working properly. If the motor is not working, the helicopter will not have enough power to fly.
Check the helicopter's circuit: Check the helicopter's circuit, if any of the circuits is damaged, it may cause the helicopter to lose power.
If none of these steps resolve the issue, it is possible that the helicopter may be defective and require repair or replacement. In that case, contact Brookstone customer support for further assistance.
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Problem with oelmaier pac2 inverter
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjckMaPzKODAxUVj4kEHR5mBFMQFnoECBQQAQ&url=https%3A%2F%2Fforums.whirlpool.net.au%2Farchive%2F1447917&usg=AOvVaw1FGjdFQoufkwdXZJgXWdGz&opi=89978449
Inverter problems
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj_qqPyyKODAxWLHjQIHZRbAW8QwqsBegQIDhAG&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DZ6e4aMeAfGQ&usg=AOvVaw1gC1aMLjnqHmsV7v7EZaQm&opi=89978449
Rca 16mm projector 201 pg no sound exsiter lam of
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiX9MCToeeCAxWXv4kEHeF-DZcQFnoECCEQAQ&url=http%3A%2F%2Fwww.film-tech.com%2Fubb%2Ff1%2Ft000301.html&usg=AOvVaw3MnkgK0sKTHX7t5pvECIT5&opi=89978449
