20 Most Recent Summit Appliances Division FEX831FS Top Load Stacked Washer / Dryer Questions & Answers
I would like to replace the water outlet valve on
Here is the service manual for your unit that will show you how to get to the water valve. This manual will help you with any further repairs should you need it in the future.
1/7/2011 5:32:22 PM • Summit... • Answered on Jan 07, 2011
Summit SPWD2200W water is left overflowing the bottom of the tub.
The washer was unbalanced.
The water pump has stop working.
The water pump is clogged.
1/26/2021 1:12:49 PM • Summit Washing... • Answered on Jan 26, 2021
I am receiving an "error 7" for my Summit SPWD2201SS washer/dryer combo. What does this error mean?
I could not find a manual for your SPW2201SS, but I did find a manual for a SPW2200SS. (Look for clogged hoses, in and out!) Sadly it only lists three 'error codes' on Page 27 and they include: E10 E21 E31 Summit SPWD2201SS Washer download instruction manual pdf
10/28/2018 11:24:48 PM • Summit Washing... • Answered on Oct 28, 2018
Hisense top loader WTCT802 8kg washing machine,
This could be down to a number of reasons. The most common of which is a displaced or faulty spin switch. This switch tell the machine that the lid is closed (or that the top is on a front loader). I know this may sound silly, but if you have a spin speed selector, double check to see that it's not been set to "0". If neither of those work/fit the problem, and also if it is showing any error codes, eg. F01/F02/UNB, please let me know
4/19/2024 3:06:17 AM • Washing Machines • Answered Yesterday
Balance systems or shocks broken. GE Spacemaker has broken stabilizers.
GE Spacemaker is a generic range of appliances. All questions in Fixya need full 'make model (what it is)', first 3 words. If the stabilizers are broken Google for parts. GE (numerical model number) Parts https://www.google.com/search?q=GE+spacemaker+parts Depending on age, they may no longer be available ..
4/15/2024 7:28:59 PM • Washing Machines • Answered on Apr 15, 2024
Dear sir, I have Primus MB205 washer extractor problem. It shows error out of order, ask for service (error 301: mits 0c2)
Question edited for spelling. You will have to do what it says and call for service. This is a Commercial Machine and not popular in North America where we are. https://www.google.com/search?q=primus+mb205+washing+machine The error is not listed anywhere https://www.google.com/search?q=error+301+mits+0c2 ..
4/14/2024 5:20:05 PM • Washing Machines • Answered on Apr 14, 2024
WASHER EXTRACTOR PRIMUS MB205 OUT OF ORDER SHOW ASK FOR SERVICE ERROR 301 MITS. 0C2
Code 301 relates to a drain failure. The rest of the code may relate to specific parts. I find no explanation available for the remainer of the code. It is likely only the manufacturer can say what that refers to. https://primuslaundry.com/en/contact
4/14/2024 11:12:07 AM • Washing Machines • Answered on Apr 14, 2024
Lay out of water tubes. I have taken apart but forgotten the layout DDS04 E01
See page 13 of the user manual. screenshot 2024-04-14 at 10.54.12-undefined-undefined-0.png
4/14/2024 9:55:10 AM • Washing Machines • Answered on Apr 14, 2024
2answers
My girbau washer flashing ALn error,how to fix it? thanks.
its should be that is the Inverter Drive error. Check to see if the cooling fan is working on the inverter. If not, then when the drive gets hot, it will cut off in the high speed extract. If the fan is working then it's probably an inverter.
4/10/2024 5:59:51 PM • Washing Machines • Answered on Apr 10, 2024
Hayward 250 HD. Control panel does not display the temperature.
I am sure I answered this yesterday? You posted to washing machines category and this appears to be a gas fueled pool heater. You would be best contacting a service engineer because it is gas powered, although if it does blow up, it is outside or will only blow up the pool house.
Universal H-Series Natural Gas 250000 BTU Low NOx
Hayward Pool Products https://hayward.com > universal-h-series-natural-gas-250... Universal H-Series Natural Gas 250,000 BTU Low NOx. Hayward. SKU: W3H250FDN. Service and diagnostics manuals https://www.google.com/search?q=hayward+250+hd+service+manual ..
4/9/2024 5:23:09 AM • Washing Machines • Answered on Apr 09, 2024
2answers
Installing transit bolts
advise you take the top off so you can see where the bolts locate
4/7/2024 9:51:13 PM • Washing Machines • Answered on Apr 07, 2024
IG IGNIS 105 LA washing machine does not show and light after a low voltage run and power surge. please guide where to look into. I am located at a remote area in Nigeria.
If your IG Ignis 105 LA washing machine does not show any lights after a low voltage run and power surge, check the power supply, main control board, and internal fuses for damage. Consider contacting IG Ignis customer support for remote troubleshooting guidance or arranging for a technician to inspect and repair the appliance.Hi Tracey and welcome to JA, sorry for the delayed response, flat out all day here,, The clicking sound you speak of, is it coming from the door latch/catch area of the cabinet,, Can you lean down for me, seta wash program and listen very closly and pin point the origin of the clicking sound,, It will either be near the door handle on the door, or behind the control panel ok, Cheers. f3zblyr-undefined-undefined-0.jpg
4/7/2024 1:25:54 PM • Washing Machines • Answered on Apr 07, 2024
Sharp washing machine model ess119
What's problem machine can't start washing and water incoming non stop?
4/6/2024 4:01:36 PM • Washing Machines • Answered on Apr 06, 2024
Summit Appliances Division FEX831FS Top Load Stacked Washer / Dryer Logo
Popular Tags
4 questions posted
Top Summit Washing Machines Experts
john h
Are you a Summit Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Summit Washing Machines
Most Popular Question
like replace water outlet valve
  • Washing Machines
