20 Most Recent
Summit Appliances Division SPDE1112 Front Load Washer Questions & Answers
Contractor and Plumber left transport rods in
it seems that your washer isn't seated properly. I don't know what type of machine you have but if you could let me know I might be able to help you with your problem. Usually with top loaders you just put your hands on the back of the machine and lift forward toward the front and that should seat your machine but not knowing the type I can't be sure.
2/3/2018 11:43:21 PM •
Summit...
Answered
on Feb 03, 2018
My top loader Hisense washing machine doesn't wash but it spins, what is the possible solution?
If your Hisense top-loading washing machine is not washing but can spin out the water, it could be caused by a few different issues. Here are a few things you can try to fix the problem:
- Check to ensure that the washing machine is properly loaded and balanced. An unbalanced load can cause the machine to stop working or not wash properly.
- Check the water supply to the machine. Make sure that the water hoses are properly connected and that the water supply is turned on.
- Check the detergent dispenser to make sure that it is not clogged. A clogged dispenser can prevent the detergent from being dispensed and the machine from washing properly.
- Check the lid switch. If the lid switch is faulty, the machine may not wash but will spin out the water.
- Check the water level switch. If the water level switch is faulty, the machine may not wash properly but will spin out the water.
- If the problem persists, consider contacting Hisense customer service or a technician for further assistance.
It's essential to note that if the machine is not washing but it can spin out the water, it could be caused by a malfunction or damage in the water level switch, the timer or even the motor.
Gorenje washing, why does it stop with 1 left ?
Your NOT suppose to "Program anything". Machines are kinda like people. After they work, they need "some" time to rest. Your machine (And Mine) all do this. Next time leave it alone, the minute will count down and it will automatically shut off. Question? You actually stood by the machine and watched the entire cycle? Was there another problem that motivated you to do this? Like your clothes were still wet or water still in the tub? If you need further help, reach me via phone at
https://www.6ya.com/expert/steven_b77d19396bfe2249
I want to bypass lid lock
It would be innapropriate to recomend the removal of a safety device.
I would repair it, not remove it.
