20 Most Recent
Activision Drakan: Order of the Flame for Windows Questions & Answers
How do I run Drakan
You need the 445 patch and run the game in developer mode by holding
shift whilst starting the game. Click on the developer tab on the box
that appears and tick enable developer mode and click OK. The game
should run as normal albiet bypassing the intro cutcene that causes the
crash.
How do I run Drakan: order of the flame, on
You need the 445 patch and run the game in developer mode by holding shift whilst starting the game. Click on the developer tab on the box that appears and tick enable developer mode and click OK. The game should run as normal albiet bypassing the intro cutcene that causes the crash.
Drakan order of the flame engine crashes
You could try installing the DirectX version the game uses. (probably on disk)
You can also try to download this Windows Virtual PC.
Windows Virtual PC emulates Windows XP on your Windows 7 PC, so that you can run older applications that won't run on Windows 7 otherwise.
You will however need a processor capable of virtualisation.
Virtualisation check and download here:
http://www.microsoft.com/windows/virtual-pc/download.aspxAfter installing Windows XP Mode you will need to install the game again in this XP emulator, but after that it should run fine.
I hope this helps,
Yannick.
I am having a problem.
Direct3D 6? Wow, the game must be way older than your computer. You probably installed DirectX 10 or later. There were major changes after DirectX 9. The software routines to manage graphics hardware acceleration through DirectX 10 or newer are probably very different from DirectX 6, so the game's graphic controller interface can't find them.
Try going into the game properties (right-click on the main executable file and select Properties from the pop-up menu).
Set it to run in XP compatibility mode and see what happens.
Check to see if the game has the option to run without hardware acceleration. If this provides acceptable performance, that is your answer.
If necessary (and if Microsoft still makes it available), try installing DirectX 6. Vista may snag on it and make you remove it and reinstall a newer version, but it's worth a shot if the other fixes don't work.
