20 Most Recent
Home Comfort HCWP1201 1.7 cu. ft. Portable Washing Machine With 12 lb Questions & Answers
What is E3
E-3 is error When spinning system does not work , after taking out all water it try to spin,
Home Comfort HCWP1201 Portable Washing Machine doesn't spin...
Sounds like the belt is either broken or slipped off,or the pulleys on the motor or basin are not turning. Most likely it will be the belt. If you can open the panel you should be able to see the problem. If it is the belt,you may find the part at any appliance shop and fix it yourself. If the pulleys are not turning the belt,there could be a few different reasons for this. You would have to look at them and find out why. They may be fixable but it would depend on the specific problem. If the machine is still under a warranty,it would be best to take it to the dealer.
Hisense top loader WTCT802 8kg washing machine,
This could be down to a number of reasons. The most common of which is a displaced or faulty spin switch. This switch tell the machine that the lid is closed (or that the top is on a front loader). I know this may sound silly, but if you have a spin speed selector, double check to see that it's not been set to "0".
If neither of those work/fit the problem, and also if it is showing any error codes, eg. F01/F02/UNB, please let me know
