20 Most Recent Haier HTE21WAAWW Top Freezer Refrigerator Questions & Answers
2answers
The freezer is working, but the refrigerator won't
TRY TO TURN THE DIAL TO MAKE IT COLDER
4/24/2017 12:19:41 AM • Haier HTE21WAAWW... • Answered on Apr 24, 2017
My refrigerator haier hte21waaww doesn't work, just the frezzer,
1...Check the fan that pushes the air from the freezer to the refrigerator it could be defective, if it is it will cause this type of problem. 2...Check your thermostat and make sure it is on the colder setting. I hope this helped you, Please rate me...Thanks
4/24/2017 12:18:10 AM • Haier HTE21WAAWW... • Answered on Apr 24, 2017
How do you remove the cover in the freezer?
remove any food shelves,then there are 4-6 screws holding rear panel in place,if it has an ice maker you need to also unplug this harness and remove icemaker
5/12/2012 12:09:47 PM • Haier HTE21WAAWW... • Answered on May 12, 2012
Freezer works (but is now
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
8/28/2011 2:47:48 AM • Haier HTE21WAAWW... • Answered on Aug 28, 2011
How will you know the fan in the top freezer part
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
1/30/2011 3:52:19 AM • Haier HTE21WAAWW... • Answered on Jan 30, 2011
Not cooling
4/23/2010 1:54:19 AM • Haier HTE21WAAWW... • Answered on Apr 23, 2010
If theires a punkture inside the frige can it
yes
2/1/2010 12:05:27 PM • Haier HTE21WAAWW... • Answered on Feb 01, 2010
HTE14WAAWW - defrost water from freezer appears to
Yes, Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
12/14/2009 5:13:17 PM • Haier HTE21WAAWW... • Answered on Dec 14, 2009
Overflow of condensation water
If you have a water filter the water will leak past the filter to the pan if it's clogged up and needs changing.
The defrost water drains to the pan, so if you are having a lot of frost it could fill it up. Excess frost can be caused by leaky door gaskets and frequent door openings.
The condenser fan near the pan should be running when the compressor runs to help evaporate the water in the pan.
9/9/2009 9:50:46 PM • Haier HTE21WAAWW... • Answered on Sep 09, 2009
2answers
Cold Freezer Hot refrigerator
I'm having the same problem with a Haier Model HTE18WAAWW.
Water is dripping into refrigerator section from the freezer section. Eventually, refrigerator section was not cooling adequately. Freezer was freezing, but there was eventually ice crystals inside similar to hoarfrost. (See Google images for hoarfrost if you're not sure what hoarfrost is.)
I turned off and unplugged unit for several hours while I removed the floor pan and internal back panel in the freezer. There was ice built up in the evaporator drain pan that was blocking the air flow of cold air from the evaporator into the refrigerator. I melted the ice with a hair drier plugged into a GFI outlet for safety.
I dried everything off. I could not find evidence of water going down the condensate drain tube below the evaporator to the condensate drain sitting on top of the compressor. I tried running a coat hanger down the drain line to no avail. I poured hot water down the condensate drain line to no avail. I put everything back together. Works fine as far as cooling and freezing, but water is still dripping into the refrigerator.
I think the defrosters are okay unless the heater strip below the evaporator is burned out. I base this on the fact that there is no condensate around the door gaskets even though the temperature in the house is hot and humid. I may have to Ohm that heater out. I'm thinking the drain line is clogged for the condensate drain. It may need longer defrosting.
If longer defrosting don't work, I'm thinking I need to rethink how to clean out the condensate drain line. Maybe low pressure compressed air???
8/29/2009 3:00:36 AM • Haier HTE21WAAWW... • Answered on Aug 29, 2009
Refridgerator not cold
low gas lewel in the system
6/17/2009 5:54:05 PM • Haier HTE21WAAWW... • Answered on Jun 17, 2009
MY REFRIGERATOR IS NOT GETTING COLD OR FREEZING LIKE IT'S SUPPOSE
check your evaporator (freezer) fan
6/13/2009 6:47:22 PM • Haier HTE21WAAWW... • Answered on Jun 13, 2009
Hole in freezer of haier refrigerator
The refrigerant used since ~ 10 years is no more dangerous than the one previously used and it is even doubtful that the newer stuff is any better for the ozone layer.
The original coolant could be inhaled without injury as long as one didnt suffocate from a lack of oxygen.
The repair may not be cheap since it will entail the removal and replacement of the damaged coil.
This will require some specialized welding to install.
Using a normal table-top or floor-standing fan to circulate ambient air through the refrigerator with the door(s) open is a safe and fast method for defrosting units that do not automatically defrost.
Just make sure you have some absorbant material in the bottom to avoid water running out of the unit.
Poking the coils with sharp objects can result in the problem you now have or fracture hidden joints that will allow the gas to escape.
5/4/2009 3:53:25 PM • Haier HTE21WAAWW... • Answered on May 04, 2009
My hte21waaww door gasket is causing my freezer to
Check all around the gasket to make sure is not broken , if it is you need to replace it,but if not and is dry and won't stick to the refrigerator,first clean with degreaser around the magnet and also where this make contact with the fridge .After this put very hot water all around the rubber gasket it will make it softer and it'll expanded after this you also can put vaseline on the gasket (is not toxic and doesn'tsmell)specially on the side by the hinges.
4/22/2009 12:29:11 PM • Haier HTE21WAAWW... • Answered on Apr 22, 2009
Fan is a big issue. New problem though.
good day!first and foremost, in most freezers, the highest freezing point is 7.in regards with the water dripping from the air vent hole, you have to minimize your your freezing setting to the middle.turn it to 3 or 4 freezing point.
4/9/2009 5:28:04 AM • Haier HTE21WAAWW... • Answered on Apr 09, 2009
Refrigerator
check to see if your condenser fan in the freezer is working
8/30/2008 8:31:34 PM • Haier HTE21WAAWW... • Answered on Aug 30, 2008
Repair
Defrost system problem will be indicated by frost (snow) on back wall or cooling coil is located in the freezer compartment. Check freezer control setting. If it is set to cold for the freezer it reduces cold air to the refrigerator section.
7/21/2008 12:56:01 AM • Haier HTE21WAAWW... • Answered on Jul 21, 2008
Haier
In units with physically separate sections, there is a fan that circulates the cold air between the two with some provision for adjusting the airflow to balance the temperature between the two chambers.
The cooling system is normally a totally closed loop that is charged in the factory through a nipple that is then pinched and welded shut.
This nipple must be cut and resealed to recharge the system.
7/19/2008 4:47:19 PM • Haier HTE21WAAWW... • Answered on Jul 19, 2008
Haier HTE21WAAWW Top Freezer Refrigerator Logo
34 questions posted
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Haier Refrigerators
  • Haier Refrigerators
Most Popular Question
remove cover in freezer
  • Refrigerators
